Thank you. I'll try that....Joe
I think I have the chrome tail pipes looking as good as possible considering they were probably flash chromed like other pieces. I will use a little silver header paint to add a little color to the areas that weren't polished before chroming.
I took to the exhaust head pipes & the pipes that go over the axle to the place that does my powder coating. They use a high heat product called Cerakote for headers so it should be just fine for the head pipes. Found a color that hopefully is close to new exhaust tubing. I'll post some pictures when they return Found the X6 that has been discussed about Norwood cars....Joe
The Following User Says Thank You to X66 714 For This Useful Post: | ||
ZLP955 (10-13-2020) |
Waiting for the exhaust to come back, here's some of the rearend. It was in good shape & original to the car. Killer 3.07 single track. Left everything stock. All powder coated with BK02 Cardinal. Closest match I could find to original pieces. Arizona plays nice with some of the chassis pieces....Joe
The Following 5 Users Say Thank You to X66 714 For This Useful Post: | ||
NorCam (10-14-2020), olredalert (10-14-2020), RPOLS3 (10-16-2020), ScottG (10-21-2020), Xplantdad (10-14-2020) |
The original leaf springs were soaked in evap-o-rust, washed completely & then hit with 0000 steel wool. Sprayed lightly with satin clear. NOS bushings used in the forward eyes. (I hope I put the spring decals in the correct place)...Joe
The car being from Tucson, all the hardware & brackets were in great condition. Original "S" shackles & bolts/nuts & NOS bushings. Original spring pockets. Original spring plates & brake cable guides. I also have NOS spring pads. All powdered back to original color. Managed to scare up some original "832" rear shocks....Joe
big gear head (10-14-2020), cruiserofland (10-14-2020), HawkX66 (10-19-2020), NorCam (10-14-2020), RPOLS3 (10-16-2020) |
