Old 10-30-2020, 10:44 PM
jbtech's Avatar
jbtech jbtech is offline
Default WTB 4.30 or 4.33 12 Bolt passenger car gears any date
Update 10/31 4.33 GM gears found. They sold them over the counter for performance applications. Learned something new!
Update 10/30 Looks like GM did not make 4.30 or 4.33's. So any aftermarket good used gears will be ok.
Looking for a good used GM gearset for my car.
I want to swap out my 3.55's.
Not particular on dates just looking for a reasonably priced original GM set if there is such a thing.
Jose
Jose Betancourt
67 Camaro L78
Old 10-31-2020, 02:41 AM
Freddie will correct me if I am wrong, but I think your options for a correct GM set of gears for a 12 bolt are going to be 3.73, 4.10, 4.56 and 4.88.
Aftermarket makes 4.30 and 4.33 gears. While they were available from the factory in Pontiacs in the late 60s, I think the BOP rear was different from the Chevy 12 bolt.
jbtech (10-31-2020)
Old 10-31-2020, 03:40 AM
jbtech's Avatar
Thanks for the info looks like aftermarket is my only option.
Anyone have some good used gears I won't need to break in?
Thanks!
Jose Betancourt
67 Camaro L78
Old 10-31-2020, 01:55 PM
lbnaz lbnaz is offline
Yenko Premier Member
I have a NOS set of GM 433's (9/39) in the box if interested. There dated 75. Contact me for more info. Larry 5203492337
The Following User Says Thank You to lbnaz For This Useful Post:
jbtech (10-31-2020)
Old 10-31-2020, 04:27 PM
jbtech's Avatar
Perfect I'll take em.
Thanks Larry!
Jose
Jose Betancourt
67 Camaro L78
Old 10-31-2020, 05:12 PM
Just for a sanity check there is no part number on the box but the pinion is 3936481 and the ring is 3936482 and both have 9/39. Can someone verify there chevy 12 bolt. I bought them on this site a year or two ago represented as chevy 12 bolt along with other GM gears. Thanks, Larry
I found in the revised special parts book dated 3-9-72 they list part number 3961430 as ring and pinion 4.33:1 ratio
Tags
12 bolt, 8.875, gears, pinion, ring
