Old 02-18-2021, 12:56 AM
Originally Posted by 3X24SPD View Post
Hi Graeme, just want to say I love the way you're putting your car together.
I've never had a Super Shifter, but I've run (& loved) a Hurst Vertical Gate in my 65 GTO for a lot of years. That's a big hole you have to try to cover in the tunnel with one of those, and you also have to use the huge boot- a lot of heat still comes through to the interior even if you try to seal it up as tight as you can. It also nixes the use of the factory console.
Is the Super Shifter an inline pattern like the Vertical Gate or is it a Standard H-pattern that's just mounted high and uses straight rods?
Thanks, Bill
Hello Bill and thanks for the comment. It was a tough decision to make but cutting the tunnel in favor of a correctly themed shifter was the way to go for this build. The stock shifter and console w/ gauges will be stored away in case I ever want to convert it back.
The Hurst Super Shifter 3 is an H pattern shifter and you are correct in that it has a high mounting position that utilizes the straight arm H/D rods. The same mount and rods are used for the inline version with that of the Hurst RamRod, and I also have one of those coming in case I ever want to swap them around for a summer.
I have a couple of boots that I plan to play around with and may have a trick up my sleeve yet. One is a B4 and I may cut down the SS3 boot and use the ring from the B4 to simply size it down to fit the small shifter box I built. More on that once the carpet is finished up, but I am having a lot of fun with this build. Now that the shifter is being changed, I'm also hoping to find a nice Lakewood 3-Point rollbar so that I can finish off the interior in Day 2 style.
