Old 05-20-2021, 11:41 PM
Still trying to find some NOS outer window felts before I start putting the interior back together, but good to be back working on the car today. I just installed the 302 callouts on the new hood, and have started to button up the motor. I'm working to find a good spot for the vacuum can and the CVR pump before I start plumbing the Hurst line loc solenoid onto the inner fender. Time-consuming work but the long weekend is coming up for us here and the weather looks like crap. That's good as I'll be out in the shop for the next 4 days and should get lots done. Still need to figure out what breather I am going to run on this setup. I'm thinking I need to find a stock 302 chrome breather.
The Following 5 Users Say Thank You to NorCam For This Useful Post:
cruiserofland (05-20-2021), dykstra (05-23-2021), scuncio (05-21-2021), X66 714 (05-20-2021), x77-69z28 (05-21-2021)
  #752
Old 05-20-2021, 11:49 PM
X66 714's Avatar
X66 714 X66 714 is offline
7729998 outer window felts in case you don't have the number. Some on e-bay...Joe
cruiserofland's Avatar
cruiserofland cruiserofland is offline
I dig those plug wire clamps
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
Old 05-21-2021, 12:26 AM
Joe,
I think the (3) part numbers for window fuzzies are 7725935 7725934 7729998 for the complete set. I have bought two sets from members here before and prefer to try that route first as I am not a fan of eBay these days and really try to avoid it. The rear quarter fuzzies are the 2 that are really needed ahead of installing the rear side panels and seats.
Old 05-21-2021, 01:08 AM
rlw68's Avatar
rlw68 rlw68 is offline
Can the outer fuzzies be replaced with the windows in?
BTW, whad up with that alternator bracket
Rob
Old 05-21-2021, 01:10 AM
X66 714's Avatar
Joe,
Didn't read it right. Thought you were just looking for the ones for the doors....Joe
Old 05-21-2021, 02:29 AM
Mr.Gasket bracket and use of another Day 2 part. It's embossed too but you can't read it in that shot.
As for the fuzzies...I'm not in any rush here so I'll put the felts in and make any final adjustments to the quarter glass before any of the rear upholstery goes back together. All good...and I have my hands full with the brakes and the engine bay right now.
rlw68 (05-21-2021), X66 714 (05-21-2021)
  #758
Old 05-21-2021, 03:57 AM
I definitely liked it better when I could work around the front end with no fenders in the way. One day putting things back together and my back is already telling me I'm getting old. I have a restored UH Coded radiator for this car but opted to install the HBC 4-core unit to help keep this solid roller motor running cool. I was pleasantly surprised this NOS shroud fit the radiator with the fan blades also being centered. As seen below, the headlamps are pre-assembled and I'm also using the T3 lamps that Fred sent me along with the car. I'll install these tomorrow and then I'm onto the front grill. I'm sorta curious to see how it all fits after making some more adjustments out at Ron's shop.
The Following 4 Users Say Thank You to NorCam For This Useful Post:
dykstra (05-23-2021), HawkX66 (05-21-2021), X66 714 (05-21-2021), x77-69z28 (05-21-2021)
  #759
Old 05-21-2021, 10:09 AM
DW31S's Avatar
DW31S DW31S is offline
Definitely not knocking, just curious about the worm clamps; nothing with a “vintage vibe” you like? I’ve always had good luck and dig the two-wire style. BTW, the car/build is off the charts, Bro.!
The Following User Says Thank You to DW31S For This Useful Post:
NorCam (05-21-2021)
  #760
Old 05-21-2021, 12:41 PM
Yes, the down stop bracket will need to be removed to allow the glass to go below the slots for the screws to be installed. Hence the need to wait with the interior panels.
NorCam (05-21-2021), rlw68 (05-21-2021)
