Old 05-30-2021, 01:56 AM
cook_dw cook_dw is offline
Banned
Default 1969 Camaro Hurst Shifter Assembly
Pulled from a purchased transmission. I do not know the history and all I did was clean it up. $700 shipped lower 48. It’s not perfect it’s 90% complete (minus the isolators, clips and reverse lever).
Attachments - The Supercar Registry EE710711-0362-446F-A1C8-A376AD1E0819.jpeg ED168FBC-43C6-48D8-B3A1-DF316C8A12CB.jpeg CF1977AB-C5A2-405E-808B-7E49B6B5A1E5.jpeg B3D2F3F9-CE36-4609-8CC1-1B0AECFC98CA.jpeg
Old 05-30-2021, 02:19 AM
bbbentley's Avatar
GLWS. Nice setup
FULL OWNER HISTORY
Old 05-30-2021, 12:53 PM
Banned
There are no numbers on the rods and I wanna make sure everyone saw the weld repair on the on rod which a grinder and some time you would never know it was welded.
Went ahead and smoothed out the weld before going on eBay.
Old 05-30-2021, 02:25 PM
In case you are not aware, that is not a '69 Camaro reverse lever.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
cook_dw (05-30-2021)
Old 05-30-2021, 03:55 PM
Banned
The levers are just included. I should have made that known in the original post.
Old 05-30-2021, 07:39 PM
The reverse lever is 68 Firebird. I imagine that is what the shifter came out of. Nice piece.
Jason
cook_dw (06-02-2021)
Old 05-30-2021, 11:25 PM
Banned
Transmission was 68 Firebird from the partial vin. Learned something today. Thanks Jason. Didn’t know 68 Firebirds had the same shifter assembly as 69 Camaro.
EDIT 6/2/21:
Wanted to add that I just discovered that the shifter handle will need knew clips and isolators. Around $40 from Camaro Central. Thought I should disclose the findings as soon as I found it.
New price due to this and the weld issue.
Also added a photo in my previous post of how the welded 1-2 rod cleaned up.
Old 05-31-2021, 05:14 PM
69L78's Avatar
69L78 69L78 is offline
PM sent
Old 06-11-2021, 01:14 AM
Banned
Now in eBay.
https://www.ebay.com/itm/154487548162
Old 06-17-2021, 12:35 AM
Banned
Less than 4 hours left on eBay.
