Old 10-19-2021, 12:01 AM
69 Post Sedan's Avatar
Default Blackjack Headers
I acquired a set of NOS Blackjack headers. The part number is 3017. Unfortunately, I can’t find that number anywhere. Does anyone have an old catalog to match it up?
The story is, they were mocked up in a 1970 Chevelle but never used.
Thanks in advance, Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Attachments - The Supercar Registry Screenshot_20240911_210307_Facebook.jpg PXL_20230505_201138611.jpg PXL_20230402_162628925.jpg PXL_20230226_173522441.jpg
Old 10-19-2021, 03:11 AM
Comparing w/ other Blackjack/Appliance Headers, they appear more Camaro like than 'Velle?
1'st pic below is your pipes compared w/ Nos '68-72 Velle pipes from this thread, note swept back angle of mid runners...
https://www.yenko.net/forum/showthread.php?p=1301952
2'nd pic is yours compared to 1'st Gen Pipes from this second linked thread, pass' side looks different for accessories perhaps but driver's almost the same other than pic angle?...
https://www.yenko.net/forum/showthread.php?p=1260298
Also of note in the second linked thread is Member Whitetop mentions he has a Blackjack Catalogue.
Best of luck!
The Following 2 Users Say Thank You to PeteLeathersac For This Useful Post:
69 Post Sedan (10-20-2021), olredalert (03-21-2024)
Old 10-19-2021, 03:19 PM
jbtech's Avatar
jbtech jbtech is offline
I have a catalog. Remind me in case I don't post the information tonight.
Jose Betancourt
67 Camaro L78
Old 10-19-2021, 04:16 PM
Chuck_Burg's Avatar
Chuck_Burg Chuck_Burg is online now
Hi Kurt! Those look identical to my Appliance CH4s, which are for 67-69 Camaro. You can see mine on my build thread.
https://www.yenko.net/forum/showthread.php?t=161440
Old 10-20-2021, 01:32 AM
rszmjt rszmjt is offline
Chuck, I think your 100% correct, before Appliance headers changed to Blackjack the CH4 number was used, pretty sure the blackjack number is 3017, same header later issue.
I put a lot of those Appliance headers on in the early 70,s when I worked at a local Calgary speedshop JB,s Automotive , very nice headers very equal length too. I have a set of CH3 headers for a small block Camaro been saving them for years. FWIW when Blackjack took over they changed to that rotating lower flange.
The Following 2 Users Say Thank You to rszmjt For This Useful Post:
69 Post Sedan (10-20-2021), NorCam (10-20-2021)
Old 10-20-2021, 04:16 PM
Chuck_Burg's Avatar
Good note on the rotating collector flange, which is probably an improvement. The Appliance headers have four hole square collector flanges.
Old 10-20-2021, 06:34 PM
I personally don't like the rotating header flange, they tend to push out and split the gasket as there is quite a bulge where the flared sealing flange is, problem gets worse as the street hook up has the same deal.
I have Tig welded the flange both sides before and then ground and Roloxed off the flared bulge. I also noticed the quality of the bends and port flanges etc got worse when they changed to Blackjack name. JMO.
I put many different make headers on the 67-69 Camaros and Appliance was the only 1 that did not have any clearance issues with steering box/pitman arm or frame fuel line. etc. Wish they still were available.
Old 10-20-2021, 08:10 PM
Chuck_Burg's Avatar
The Appliance fit in my 67 like a glove! I was very impressed when I installed mine.
Old 10-22-2021, 03:34 AM
jbtech's Avatar
Enjoy.
Jose Betancourt
67 Camaro L78
The Following 3 Users Say Thank You to jbtech For This Useful Post:
69 Post Sedan (10-22-2021), Chuck_Burg (10-22-2021), PeteLeathersac (10-22-2021)
Old 10-22-2021, 05:33 PM
WW also cool they're B-Body!
Note the 'Vette pipes are the only other application shown w/ 2" runners and 3-1/2" collectors.
As above, they're similar to F-Body so may swap/fit one or both applications?
