Old 11-04-2021, 01:34 PM
wthirty1 wthirty1 is offline
Default Fisher Body Sill Plate Rivets
The NOS set of sill plates I used for my '70 don't have the rivet on each side of the Fisher Body tag like the factory sill plates. What has this group done to replicate the rivet? Thanks
1970 Cutlass S W-31 - platinum, blue stripes, blue buckets, M14 3-spd
1970 Cutlass Supreme Y74 Pace Car #79 - IU Little 500 Pace Car
1970 442 - white, red stripes, white buckets, M21 4-spd
Old 11-04-2021, 02:04 PM
SS427's Avatar
SS427 SS427 is offline
You can buy the correct size rivets from a hobby shop made for HO trains. Drill, insert the rivet and peen over on the backside. (package shown is a sample only, confirm your needed size)
Another trick is to use a finish nail punch with the concave recessed head and lightly tap it in the exact location that a rivet will be. It will be a correct size and shaped head on the Fisher tag and once a small dab of silver is added it looks very legit.
Rick Nelson
The Following 7 Users Say Thank You to SS427 For This Useful Post:
Jims69z28 (11-12-2021), L_e_e (11-08-2021), NorCam (11-04-2021), olredalert (11-12-2021), PeteLeathersac (11-04-2021), Slob44 (11-04-2021), thehornworks (11-08-2021)
Old 11-04-2021, 02:38 PM
Thanks, Rick! I was hoping you'd have a solution.
Old 11-04-2021, 03:03 PM
William William is offline
Like so
Old 11-07-2021, 11:22 PM
Unreal Unreal is offline
I salvaged rivets from old worthless sill plates by grinding them from the back side, and drilled and glued them in place. As I recall, I had later NOS sill plates (ones in a shrink pack) that did not have the rivets. Note that most of the rivets I have seen have tool marks that are not concentric with the rivet.
Old 11-08-2021, 01:45 AM
XXXGoldL34M20's Avatar
x2
Always pick up junky beat up sill plates to get these as well ! I re use the original rivets by just glueing them on the back side with super glue !
Old 11-08-2021, 06:27 PM
Originally Posted by XXXGoldL34M20 View Post
x2
How were you able to get the original rivets out?
Old 11-08-2021, 09:50 PM
I just hit the rolled part of the rivet on the underside of the sill plate with a grinder, and popped the rivets out. As I recall, my newer NOS sill plates already had the Fisher tags glued on, so I just drilled holes in the correct spots, and glued the salvaged rivets in place.
I also salvaged a few pretty nice Fisher Body tags from the junky sill plates, but never used them. I haven't seen them in years, so they may be gone forever. I don't know.
Again, in the event you install rivets as Rick does, the tool mark "dimple" on the top of the rivet was almost almost always a bit off center.
The Following User Says Thank You to Unreal For This Useful Post:
XXXGoldL34M20 (11-08-2021)
Old 11-11-2021, 11:09 PM
I wonder when GM stopped the rivet process as the NOS sill plates I placed in our 68 were purchased in 1979 (have receipts) and had rivets.
68,69&2015 Z/28's
Few Corvettes
Old 11-12-2021, 12:30 AM
Mine were in shrink wrap packaging, and they were among the NOS parts when I bought the car in '93. I don't know if there were dates on the packaging.
