![]() Quote:
Bill Last edited by Big Block Bill; 01-11-2022 at 12:04 AM. |
The Following 2 Users Say Thank You to Big Block Bill For This Useful Post: | ||
danachevroletfor1967 (01-11-2022), Xplantdad (01-11-2022) |
Well after having the car in a local auto repair shop for 2 days they could not find where there was a battery drain. They charged the battery and told me that it was their opinion that the problem was either with the battery not holding a full charge anymore or with the ignition switch in the steering column.
I have been checking the battery charge and it has never been below 12.0 volts and today was 12.5 after the car has sat for a few days. It does appear that there is no longer a drain or at least no longer enough of a drain to weaken the battery. I am going to keep my eye on things and if they revert to like they were before look into getting a new battery and maybe taking my car to another shop. I did purchase a battery cut off switch but haven't installed it yet due to the car behaving normal lately. |
The Following User Says Thank You to danachevroletfor1967 For This Useful Post: | ||
BB70 (01-23-2022) |
I had a lot of 4th gens, never really had this problem, maybe look for a break in the wire?
The Following User Says Thank You to Pro Stock John For This Useful Post: | ||
danachevroletfor1967 (01-10-2022) |
Reading this made me think about my 02 car so I went to the shop to try it. I haven’t driven it for about 4 weeks, hit the key and it fired right up. A bought a new AC Delco battery for it in June 21. No issues with the battery
Dana you’ve got a problem with that circuit and it can be fixed. Going to take some time n effort but you can fix it. Good luck,
Richard 1967 Camaro SS 396/375 4K 2002 Camaro 35 Anniversay Z4C-WU8 |
The Following User Says Thank You to 1967 4K For This Useful Post: | ||
danachevroletfor1967 (01-11-2022) |
It has been my experience that a drain in the radio circuit is the radio. Is there a CD in it now? The drain can be a switch internally sensing and causing the drain.
1971 Boss 351 , 17,000 miles .. 1971 Buick GS455 .. 2003 SVT Cobra .. 1971 GTO .. 1969 Camaro Fathom Green .. 1969 Camaro Hugger Orange .. 1970 Buick GS455 .. 1970 BUICK GS350 .. 1998 SVT Cobra 1900 miles;. 1973 STAGE 1 GS . 1971 Mach 1 351C 4 speed , first car. 1970 Mach 1 428 SCJ . 1970 SS 350 Camaro . 1971 442 ... 1968 Buick GS400 . 2015 Lexus IS 350 F Sport 2021 Badlands Bronco Sport |
The Following User Says Thank You to ScottG For This Useful Post: | ||
danachevroletfor1967 (01-26-2022) |
Get a battery tender and leave it hooked up whenever you're not driving the car. The battery tender will keep the battery fully charged to it's optimum capacity and make your battery last a lot longer. I have a 97 30th Anniv Camaro and that's what I do...I don't drive the car that often particularly here in Chicago during the winter months so the battery tender is always hooked up. It is so sensitive that if you open the door and the dome light comes on the battery tender goes right into the charging mode and take the battery back to optimum charge. Hook up a battery tender and forget about it and your problem will be solved.
1970Camaro Z28 |
The Following User Says Thank You to 70 Forest Green Zee For This Useful Post: | ||
No, there is no CD in the player now. There is no light on right at the entrance to where a CD is inserted.
