Old 11-07-2021, 04:07 PM
Default WTB: 4 mint FW 15 x 7 rally wheels
I am in need of 4 mint used FW code, 15 x 7 rally wheels, dated K-1-1 1 hole 16. Thanks, Don.
Old 12-24-2021, 02:59 PM
Bump!
Old 12-25-2021, 03:18 PM
Copo_Cartel's Avatar
Yenko Premier Member
Don I did have as many as two or three if that helps you Doug 614-203-1272
Old 02-17-2022, 08:48 PM
Lynn Lynn is online now
https://www.ebay.com/itm/19476461859...YAAOSwYFpfx9xb
Don't know if you can make a deal excluding the aftermarket rings and caps, but worth a try.
Last set I had I was lucky to get $200 for the set. In hindsight, I should have kept them. They are so close to YH wheels in dimension that most folks can't tell the difference with the rings and caps on. Could have used them as a spare set of wheels/tires for my Z.
Old 02-17-2022, 10:51 PM
What does "1 hole 16" stand for?
I have (4) FW wheels dated K 1 7 7, (1) FW wheel dated K 1 9, and (1) FW wheel dated J 1 15 They all have been blasted, have good lug holes, and I believe are true, but I can double check on my Hunter Road Force Wheel Balancer. PM me if you are interested with your e-mail address I'll send you some pictures.
Bill
Old 02-17-2022, 11:33 PM
I think it is K=Kelsey
first 1 = Chevy
second 1 = January
Then the valve stem hole
Then 16 = 16th day (of Jan)
Forgot he was looking for specific date when I posted that link. Ad says "mixed dates" so I didn't likely do anyone a favor..... just muddied the waters a bit. Boy, I am really good at that.
Used to be a saying: "Think before you speak".
Guess the modern equivalent is: "Think before you type and hit the send (or post) button.
