Old 03-14-2022, 11:59 PM
Tommy Tommy is offline
Default Sway bar ID
I need some assistance deciphering this rear sway bar and links. I would like to say it's for a Nova but I can't be sure. It's been in the trunk of my 69 Z since I bought it but I am just now unpacking the contents of the car. There is nothing under the Z to make me think it was ever fitted to the car so it's just something that was thrown in the trunk at some point.
Tommy
Attachments - The Supercar Registry Nova Sway bar.jpg IMG_20220313_193204755.jpg IMG_20220313_185532570.jpg
Old 03-15-2022, 12:13 AM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
Looks alot like the one on my 70 Z/28 so maybe early 2nd Gen Camaro ??
Old 03-15-2022, 11:11 AM
JRSully JRSully is offline
might be a 71 or later Nova bar.?
71 Porsche 911 Targa
Old 03-15-2022, 07:40 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Measure the overall width, I have bars I can check against.
At first glance it looks like the wider Gen two F body style.
70 Chevelle SS-454 LS-5 M-22
Old 03-15-2022, 11:54 PM
42" overall. The links are 13".
Tommy
Old 03-16-2022, 01:23 PM
L78_Nova's Avatar
1st Gen Camaro and 3rd Gen Nova rear bars are about 38-1/2" (although of 3 bars I have they are all slightly different lengths + - 1/2")
I have some later (probably 78 up) Camaro/Trans Am ones that are close to 45"
I'm stumped on 42'
Gary
Old 03-16-2022, 01:36 PM
L78_Nova's Avatar
Were the early 70's Camaro diffs narrower than the later stuff ?
Old 03-16-2022, 08:55 PM
Zman1969 Zman1969 is offline
70-81 same 61" wheel to wheel links were different on early VS later
what Diameter is the bar it looks like early with small bushings on links
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 03-17-2022, 03:10 AM
L78_Nova's Avatar
The 38-1/2" bars fit on the spring plates which are extended towards the inside of the leaf springs.
Is it possible there are different spring mounting plates where the bushings would be mounted directly under the center of the leaf springs ?
Old 03-17-2022, 03:26 AM
L78_Nova's Avatar
Default sway bar
Pretty Sure it is 4th gen Nova bar which mounted the bushing directly below the inner spring plate bolts
Here's a pic of what is claimed to be a 77 Nova bar on a 73 Nova
Name:  Nova Sway bar.jpg
PeteLeathersac (03-17-2022)
