Old 04-06-2022, 12:34 AM
nugeusa1's Avatar
nugeusa1 nugeusa1 is offline
Default Block usage for early 11C L78 69 camaro
Im restoring a 11C 69 L78 assembly date 1116 Jh per POP . My plan is to build a a open chamber L78 with 074 heads for now while i search for the born with block, it a long shot but its a local car and still hopefull i can find it. My question is would it be a 440 or 272 casting? Thanks for your help , id at least like to put the rite casting back in. Nuge. O,i do know their wasnt any open chamber l78’s , i just have a nice set of 074’s and thought id use them.
Old 04-06-2022, 01:29 AM
William William is offline
I was curious also, so I buzzed through our db.
Latest build date for a 440 block is October 17, latest cast date G168.
Earliest build date for a 272 block is September 17, earliest casting date H18.
With an 1116 build date, the OE block in your car is virtually certain to be a 272.
The Following User Says Thank You to William For This Useful Post:
69M22Z (04-06-2022)
Old 04-06-2022, 01:56 AM
WILMASBOYL78's Avatar
Post Open Chamber L78...
You will not have the L78 11 to 1 compression with those heads...not sure if they make an open chamber compatible piston for that setup?
Good luck...
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
