Old 11-28-2022, 09:13 PM
Crossbreed383 Crossbreed383 is offline
So here is the frame being etch primed,epoxy primed and then painted and control arms getting cleaned up as well .
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
The Following 4 Users Say Thank You to Crossbreed383 For This Useful Post:
big gear head (11-29-2022), dykstra (11-29-2022), kwhizz (12-02-2022), L78_Nova (11-29-2022)
  #32
Old 11-28-2022, 09:20 PM
I added new control arm bushings and ball joint
I was initially going to use the rivet looking ball joint bolts ,but they looked weak so i went to Fastenal and found some grade 8 button head bolts and used a hex nut underneath .
Added some JB weld,some sanding and paint and they sort of pass OK for rivets to most ..
Control arms with ball joints and bushings added and ready to install...
The Following 7 Users Say Thank You to Crossbreed383 For This Useful Post:
69M22Z (11-28-2022), big gear head (11-29-2022), Dave Rifkin (11-30-2022), dykstra (11-29-2022), L78_Nova (11-29-2022), NorCam (11-30-2022), olredalert (11-28-2022)
  #33
Old 11-28-2022, 09:26 PM
Then came the restoration of as much of the front end steering components as possible
Luckily most of it was usable so it was cleaned, paint markings were noted and parts then restored as best as possible ...
Here is everything clean and inspected before rebuilding.
The Following 10 Users Say Thank You to Crossbreed383 For This Useful Post:
69M22Z (11-28-2022), big gear head (11-29-2022), Crush (11-28-2022), Dave Rifkin (11-30-2022), dykstra (11-29-2022), gtomike1967 (11-29-2022), L78_Nova (11-29-2022), NorCam (11-30-2022), olredalert (11-28-2022), RPOLS3 (11-29-2022)
  #34
Old 11-29-2022, 02:54 PM
dykstra's Avatar
dykstra dykstra is offline
Looking great!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
Old 12-01-2022, 11:31 PM
Finishing the front end and brake components and rebuilt the calipers.
I have the correct 68' dual piston calipers but the 2 piece rotors were too thin for use ,and they are heavy compared to the single pistons, so those were used .
The Following 6 Users Say Thank You to Crossbreed383 For This Useful Post:
'69Novajoe (02-08-2025), 69M22Z (12-01-2022), COPO (12-03-2022), dykstra (12-02-2022), L78_Nova (12-02-2022), Xplantdad (12-01-2022)
  #36
Old 12-01-2022, 11:40 PM
Then I rebuilt the 68' Manual steering box with new bushings,etc.
The Following 3 Users Say Thank You to Crossbreed383 For This Useful Post:
69M22Z (12-01-2022), dykstra (12-02-2022), L78_Nova (12-02-2022)
  #37
Old 12-01-2022, 11:59 PM
Tie rod adjusting sleeves and rear end frame bump stops cleaned up and refinished.
The Following 2 Users Say Thank You to Crossbreed383 For This Useful Post:
  #38
Old 12-02-2022, 12:05 AM
Cleaned up some low mileage rotors and drums from another car . The drums still have the adjusting knock out plugs and rotors have ink stamps.
  #39
Old 12-02-2022, 12:13 AM
Painting the 12 bolt assy . Cant find the assembly pics but it consists of the following..
68 12 bolt housing
Detroit True Trac Posi unit
4.10 Richmond gears
Strange Axles
  #40
Old 12-02-2022, 12:23 AM
Rear backing plates and rear brake assemblies rebuilt. Also detailed the rear brake hose bracket and the original hose retaining clip as the aftermarket clips are incorrect.
cheveslakr (12-06-2022), dykstra (12-02-2022), L78_Nova (12-02-2022), Xplantdad (12-02-2022)
