Old 01-18-2023, 05:37 PM
Andy Andy is offline
Originally Posted by Too Many Projects View Post
I thought you were going to buy the repro face plate. The one in the pic appears to be all one panel too. But, if it is just a separate delete plate, it would have studs that go thru the stem holes with washers/fasteners on the backside.
I am. I can't find a repro that's all one panel. Looking really close at the one in that car it looks like it may have a plate on it too. My car has A/C & heat so I guess mine would look like his when I put the block off plate on it, or as close as possible anyway.
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
Old 01-18-2023, 06:04 PM
Found it in the factory assembly manual.
Andy
1972 Duster 340 727
Old 01-18-2023, 07:59 PM
jbtech's Avatar
jbtech jbtech is offline
This is an original GM Radio cover plate.
Jose Betancourt
67 Camaro L78
The Following 5 Users Say Thank You to jbtech For This Useful Post:
69M22Z (01-20-2023), Andy (01-18-2023), dykstra (01-18-2023), olredalert (01-19-2023), X66 714 (01-18-2023)
  #14
Old 01-18-2023, 08:31 PM
The pic I posted is a repro, radio delete face plate, but it's all 1 piece, not like original with an add on plate for the radio hole. Top hole is heater controls and bottom is ash tray.
Here are 2 vendors with repro delete only plates.
https://www.heartbeatcitycamaro.com/...GM%23-3893845/
https://www.classicindustries.com/product/rd01.html
Andy (01-18-2023)
  #15
Old 01-19-2023, 02:50 PM
Does any company make a dash radio repair panel for 67/68 Camaros? The only thing I see is the entire dash assembly. Looks like I'll have to repair the dash anyway to use this delete panel.
Andy
1972 Duster 340 727
Old 01-19-2023, 09:03 PM
Since you are just going to cover the area, I would fashion a panel by hand from sheet and weld or rivet it in... It only needs to hold the delete plate.
Old 01-20-2023, 04:46 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Post a want ad here and maybe somebody will have a section of the metal dash that you are looking for.
