Go Back   The Supercar Registry > General Discussion > AMC
Old 05-16-2024, 07:59 PM
Daverde Daverde is offline
I never have seen valve covers like those !neat
Old 05-19-2024, 04:04 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is offline
Small update for today.
Have been working on the car a little bit but work has been crazy lately. Have a couple of weeks off coming up so hopefully I can get the exhaust finished and start to button up odds and ends. Hopefully by the end of June it’ll be tagged and legal to drive and go to a couple local shows before MCACN. It’s not the prettiest thing but I bet it’s the only SC360 wherever it goes.
I’ll add a few more pics later. I’ve been fighting a cold the last few days and have been forgetting to take pics and stuff.
AMC weirdo
The Following 5 Users Say Thank You to LetsFNgo For This Useful Post:
big gear head (05-20-2024), markinnaples (05-20-2024), PeteLeathersac (05-20-2024), Pro Stock John (05-20-2024), Tenney (05-20-2024)
  #33
Old 05-23-2024, 05:08 PM
LetsFNgo's Avatar
Had some time to mess with the car today, I’ve been sick the last few days but when the cold meds kicked in I would work in the garage a little.
I got the gauges mounted and began running the wiring. Still need to wire the temp gauge and the lights, along with tucking all the wiring away nicely. Began tying up all kinds of things so it doesn’t look so thrown together under the hood. And got the exhaust all finished. It’s hitting a bolt for the driveshaft loop so I’ll need to do a little clearancing to make everything fit right. But overall I’m happy with it and the car sounds much better through mufflers.
Got the 4 slot mags dismounted from the old tires. My dad is going to spend some time cleaning them and next week at Ford Carlisle I’m going to try to find some tires for them. It’s 14x6 on the front and 15x7 for the rear.
Also was able to get almost every light working, along with the idiot lights in the dash. Brake lights and turn signals work, even the key buzzer works, and damn is it annoying.
AMC weirdo
The Following 9 Users Say Thank You to LetsFNgo For This Useful Post:
big gear head (05-23-2024), gtomike1967 (05-23-2024), jer (05-23-2024), L78_Nova (05-23-2024), markinnaples (05-25-2024), olredalert (05-24-2024), PeteLeathersac (05-24-2024), Pro Stock John (05-23-2024), Tenney (05-24-2024)
  #34
Old 05-23-2024, 10:45 PM
GMC_Typhoon GMC_Typhoon is offline
I like it.Never seen one.My grandpa worked for AMC in the 50's/60's pulling engine blocks out of the oven.
The Following User Says Thank You to GMC_Typhoon For This Useful Post:
LetsFNgo (05-29-2024)
  #35
Old 05-29-2024, 08:12 PM
LetsFNgo's Avatar
Not much for pictures. But I’ve been driving the car around a little the last 2 days. Got insurance put on it and put the title in my name. It was an old brown NJ title and it’s a bit of a pain since NJ doesn’t like their old titles when transferring a vehicle. The car is surprisingly quick. More so than I expected.
Overall it seems to run good. Still have a ton to finish up and put together. And I’m in need of the headlight surrounds next to the grille. I have a NOS set but I don’t have the little corner marker light lenses for them. Hopefully I can find some used stuff at AMO in Virginia in a couple of weeks.
I also need to find tires for these slot mags. Hopefully Carlisle on Friday will provide tires for this and wheels for the Gasser Rambler I’m building.
AMC weirdo
The Following 7 Users Say Thank You to LetsFNgo For This Useful Post:
1967Z28 (05-30-2024), big gear head (05-30-2024), gtomike1967 (05-30-2024), jer (05-29-2024), L78_Nova (05-29-2024), markinnaples (06-14-2024), Tenney (05-31-2024)
  #36
Old 06-04-2024, 02:40 PM
LetsFNgo's Avatar
Little update. Went parts hunting and found some other Magnum 500’s for the front. And I love Magnum 500’s. They’re one of my favorite wheels. So between the H50’s out back and the new fronts I’m very happy.
On a separate note, had the car out for about 50 miles yesterday. I had to run to my engine machinist about the Gasser engine block. And make a few other errands. I took the Hornet, but unfortunately I didn’t make it home lol. It started making noises in the rear about 20 minutes from home and I made it more than halfway from there before the wheel bearing came apart and allows the axle to walk and kill all motion. It ended up on the same flatbed that rescued the car when I bought it. I already have the car apart and hopefully next week I can replace all the seals and bearings so I won’t have to worry about it again.
AMC weirdo
The Following 4 Users Say Thank You to LetsFNgo For This Useful Post:
1967Z28 (06-05-2024), gtomike1967 (06-04-2024), markinnaples (06-07-2024), Tenney (06-05-2024)
  #37
Old 06-05-2024, 12:39 AM
Dang, that bearing was as dry as a popcorn fart, from all those years of sitting.
Old 06-05-2024, 01:23 PM
LetsFNgo's Avatar
Yes, I may have been a little lax on inspecting the questionable non-original rear axle lol.
AMC weirdo
The Following User Says Thank You to LetsFNgo For This Useful Post:
  #39
Old 06-12-2024, 12:48 AM
LetsFNgo's Avatar
Little update
Got the car all put back together. New axle bearings and seals, fresh oil and added posi additive this time. Car drives much nicer so I’m assuming those bearings were junk from the get-go and I probably should’ve changed them when I initially was going through the car. But it’s all fixed now. Drove it about 25-30 miles yesterday. It’s a fun awesome car and I’m enjoying it more than I expected.
Something else I found funny. I was talking to Henry the old owner today, and he told me himself and all his friends called the car The Toad. He says because the car jumped off the line so fast. He had 4.88’s in it. Though I also think the car looks like a toad. So now it’s The Toad.
AMC weirdo
The Following 10 Users Say Thank You to LetsFNgo For This Useful Post:
1967Z28 (06-14-2024), 69M22Z (06-12-2024), big gear head (06-12-2024), Dave Rifkin (06-12-2024), juliosz (06-12-2024), L78_Nova (06-12-2024), L_e_e (06-12-2024), markinnaples (06-14-2024), olredalert (06-12-2024), Tenney (06-12-2024)
  #40
Old 06-12-2024, 02:43 PM
----Quite a transformation!....Bill S
LetsFNgo (06-12-2024)
