Old 05-04-2021, 06:17 PM
Krateness Krateness is offline
Default Correct 1969 Big Block Starter W/ Auto Transmission?
Trying to piece this together. I’m trying to figure out what starter I need for a COPO car with an automatic trans. I’ve seen 1108430 listed for automatics and 1108418 for manuals. However, in trying to hunt for a 1108430, I can’t find anything dated before 1970?
Anyone help shed some light on this for me?
Attachments - The Supercar Registry starter noses.jpg starter bolts.jpg obstarterdate.jpg obrhexhmansmogdate.jpg
Old 05-04-2021, 07:09 PM
X66 714's Avatar
X66 714 X66 714 is offline
FWIW My born with starter on my 8/28/1969 325hp with th400 is an 1108418. Don't know about COPOs though....Joe
Old 05-04-2021, 08:37 PM
William William is offline
Depends on which COPO.
The 1969 Chassis Service Manual lists 1108418 for all 396 engine/transmission combos. L72 was not listed but no reason to believe it would be different.
ZL-1 automatics substituted 1108400, possibly due to the higher compression.
The Following User Says Thank You to William For This Useful Post:
X66 714 (05-04-2021)
Old 05-04-2021, 09:39 PM
Thanks guys for the response, the car is a 427 COPO. I just read across it and was curious as if I had my thinking messed up. When the car was purchased it didn’t have the original TH400 behind it. I just remembered it not being the correct 418 starter. I went out just note to check at what came off of it and of course it’s a 430. However it is dated for 1974. I’ll probably just go ahead and snag a 418 and call it done.
The Following User Says Thank You to Krateness For This Useful Post:
L79Chevelle (05-09-2021)
Old 05-04-2021, 09:43 PM
Ralph Spears's Avatar
I had a 1969 Corvette 427/435 M40 and it had 1108400 starter
Old 05-05-2021, 03:58 PM
crash crash is offline
My 1971 LS-5 4-speed Corvette has a 1108400 starter... Crash
Old 05-05-2021, 08:14 PM
Corvettes are listed separately in the Chassis Service Manual.
Camaro, Chevelle and Nova w/396 engine list the same 1108418 starter.
B-body w/427 also shows the 1108418.
Old 05-06-2021, 05:23 PM
L78 Fred L78 Fred is offline
What date 418 are you looking for?
Remember is should have the stainless heat shield as well- for both M40 and 4 speed
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
Old 06-13-2024, 05:54 AM
My 9 K 22 ...1108418 starter has Aluminum Nose Casting...
What application was this ????
Could this Sept Starter still have been used for late 69 Camaros ???
Thanks
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 06-14-2024, 06:25 PM
daveg's Avatar
daveg daveg is offline
Not exactly what you seek but this is on a third week of Feb Baltimore L78 M22 Chevelle.
Cast nose and motor brush painted Lemans Blue with a brush.
Couple views of the afore mentioned shield.
Tube nut for solenoid attaching point is in console.
Twisted off stud is why the starter- head shield had a photo- op.
