Old 10-11-2024, 02:22 PM
427yenko 427yenko is offline
Default Compressed Air Piping
Hi everyone. Looking for advice on the best air piping to use for garage compressed air system. I would like to conceal in the walls and above the ceiling for the installation method. What is everyone using?
Thanks!
Bob
Attachments - The Supercar Registry FBE58E89-939E-44AC-B0CC-1F1F08B4DB8F.jpg ACAC639A-6DE4-4F45-9BAC-3993736AFEDE.jpg
Old 10-11-2024, 02:53 PM
X66 714's Avatar
X66 714 X66 714 is offline
I used black iron pipe throughout the garage also behind the walls. I used T111 exterior siding inside held on with sheet rock screws. I collect signs so that's why the siding. The screws so you can get in there if you need to. It's been 12 years & no problems. I also ran the electrical behind but mounted it about chest high in case something was stacked on the floor....Joe
The Following 2 Users Say Thank You to X66 714 For This Useful Post:
69M22Z (10-11-2024), big gear head (10-11-2024)
Old 10-11-2024, 04:09 PM
Igosplut's Avatar
Igosplut Igosplut is offline
Black iron because it acts like a cooling agent, where plastic, or rubber insulates. I had a diagram I posted before that shows the proper routing and drops, but I can't find it now.
WOT
Old 10-11-2024, 04:35 PM
169indy's Avatar
169indy 169indy is offline
My "Rapid-Air" Plastic system has Constant issues, Sad I went this route now.
"MAXLINE" system.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 10-11-2024, 06:01 PM
Tuna Joe Tuna Joe is offline
I went with copper lines.
Old 10-11-2024, 06:17 PM
lbnaz lbnaz is online now
Yenko Premier Member
Black iron or type L copper pipe.
Old 10-11-2024, 06:19 PM
X66 714's Avatar
I ran all the piping high & when it stubs out at the wall each one has a ball valve shut off & also a drain about a foot below the tee coming out of the wall....Joe
Igosplut (10-11-2024), scuncio (10-11-2024)
Old 10-11-2024, 08:01 PM
Igosplut's Avatar
What he said.
WOT
The Following 2 Users Say Thank You to Igosplut For This Useful Post:
scuncio (10-11-2024), X66 714 (10-11-2024)
Old 10-11-2024, 09:43 PM
----Not kosher, but when I built my cave we buried the lines in the walls. My suggestion is that if you have anything behind a wall be sure to triple test the system. I now have to shut off mine at night, which isn't too big a deal. I have so much crap in front of the walls that I just can't imagine trying to fix the minor leak I have. If I forget it takes several hours to blead down....Bill S
Old 10-11-2024, 10:21 PM
napa68 napa68 is online now
I used the Rapid Air Rapid Pipe (aluminum pipe) about 5 years ago. I'm really happy with the product. I myself would be a bit skeptical about being sandwiched in the wall in the event of a leak or failure.
https://www.rapidairproducts.com/sho...-ft-master-kit
Nonetheless, the fittings were high quality and the system it easily added on to.
Tim
