The Struggle Continues.....Owner of machine replaced badly worn nozzle/tip
This made quite a bit of difference, but this Black then Gray Primer not coming off fast............but I'm almost done.........I only have access to blast cabinet during limited hours....... This Air Cleaner has been sitting for 25 years off of car before I bought it.........so I suppose it could have been epoxy primed back in the 80's or 90's ??????? I am using NEW 100 grit Red Garnet Sand.............
Chuck Sharin [email protected] Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78, R/S SS 69 Camaro COPO "recreation" |
The Following User Says Thank You to CamarosRus For This Useful Post: | ||
69M22Z (01-23-2025) |
With a new tip and fresh grit, that primer will come off for sure. DO NOT concentrate the blast in one are for an extended period, you can warp the metal if it gets too hot/too thin
70 L78 Nova Fathom Blue,Bench, 4spd, F41, 3:55 71 Porsche 911 Targa |
Primed and painted inside is definitely not original. Aftermarket part ? Condition looks too nice to have warranted a repaint years ago. What did it look like before you felt it needed paint ?
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
enio45 (01-24-2025) |
Sully, I'm moving the gun/tip in a sweeping motion and the TWO coats of Black and Primer are coming off........just not real fast.....anyway Im almost done with paint removal.......Now have to finesse flared ends of snorkels before I give to my painter for
??? primer and Single Stage GLOSS Black....... Too Many Projects, This Air Cleaner is definitely original as the metal is crinkled in the distributor relief area. Black Paint was Chipped, Scratched etc......This area cleaner (or one like it) is for my LEGENDS 70 R/S Z28 so needs to be better than NOS.............
Better than NOS?
Jason |
Looks Good Chuck, I'd say your almost there. Don't leave it bare metal too long, it could flash rust pretty quick if left in a moist environment
That is not surprising if the primer is an epoxy....or even just a thicker coating of a non-catalyzed primer.
Patton Glade 70Post Restorations Austin, TX |
When you blast the paint gets hot and can soften up. Keep moving and come back to areas that need more.Soft paint doesn't come off as well.
The Following User Says Thank You to thehornworks For This Useful Post: | ||
SS427 (01-24-2025) |
