Old 03-03-2025, 06:22 PM
Default Aluminum Water Pump Rebuild
Calling DIYers: Anyone use one of the rebuild kits (link below)? My aluminum short pump part number is 3975928 (GM OTC for BBC applications). Multiple vendors provide kits but, can not confirm whether the kit can also work with an aluminum pump, only that they are for 396/427 application. Most of the pumps for this application are, of course, cast iron.
Thanks, Sam
https://www.zip-corvette.com/66-74-4...build-kit.html
Attachments - The Supercar Registry waterpump 16.jpg IMG_5258.jpg 100_5856.jpg 100_5855.jpg
Old 03-04-2025, 04:23 AM
169indy's Avatar
169indy 169indy is offline
I source the Ebay Kits that come with a Cast Impeller & single pattern drilled hub.
I do pumps DIY style and have never tried doing a Alum, I wonder what the added risks are given the delicate alum structure. As in Support could be WAY more critical of a softer metal structure?
Hum
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
mockingbird812 (03-05-2025)
Old 03-04-2025, 11:54 AM
I had my aluminum pump rebuilt a few years ago. The company that did it wouldn't disassemble it, so I had to do that myself. They said they couldn't guarantee that they could get it apart without breaking the casting. I took it apart and sent it to them and they did a good job putting it back together.
Old 03-04-2025, 12:15 PM
KevinW KevinW is offline
I looked at the Zip stuff a while back, but their offering on the long water pump kits did not look proper to me.
I bought a few of these kits from these guys in Oregon off Ebay. They worked perfectly for my cast iron 69 Camaro water pumps. Supporting cast iron pumps in the press is very important, I would think Alum ones are even more important!
1969 Chevrolet Camaro Z28 302 5.0L V8 New water pump rebuild Kit 3927170 3953692 from 2ndgenautoparts
69 327 convertible (driver)
The Following 2 Users Say Thank You to KevinW For This Useful Post:
69M22Z (03-04-2025), mhm1966 (03-04-2025)
Old 03-04-2025, 03:02 PM
Tuna Joe Tuna Joe is offline
I second using 2ndGenautoparts off EBay.
Very nice quality rebuild kits.
And, great customer service. I rebuilt my first water pump last month and the owner texted me to answer my questions.
The Following User Says Thank You to Tuna Joe For This Useful Post:
Old 03-04-2025, 05:27 PM
MarcDant's Avatar
MarcDant MarcDant is offline
Good day Sam, TRACY PERFORMANCE 1 586 722 0000 can help you out. I think you have 1 extra 5 in your part number. He has done 3975928 pumps before and could supply a kit for you. Marc.
The Following User Says Thank You to MarcDant For This Useful Post:
Old 03-04-2025, 08:55 PM
169indy's Avatar
Cool
Be VERY careful at Home
LOL
My 68Z Pump! - Gone done by ME!
Sometimes you just end up kicking your own arse
It was dated 66' and was serviced at some point. I ended getting a 1967 dated correctly from a vendor. They (GM) went to a larger Bearing in 1970' I think and making sure you get the correct kit is important. Then Properly Setting the internal seal is tricky that required special tooling
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 03-05-2025, 03:55 AM
Wow,all good inputs. I appreciate yr suggestions and YES I did add an extra “5” in my part number. Good catch. I’ll report back on which direction I go.
Thanks again!
Best,
Sam
Old 03-05-2025, 03:26 PM
LOL
YOu are a courageous man showing a sad outcome but, you’re willingness to show the rest of us so we can learn from you is noteworthy. I doff my cap to you sir!!
The Following 2 Users Say Thank You to mockingbird812 For This Useful Post:
169indy (03-10-2025), olredalert (03-05-2025)
Old 03-10-2025, 03:59 AM
Update. I have a GM aluminum water pump due here this week. I received the rebuild kit from 2ndGenAutoParts. I also got their 3D printed special tool to install the bearing to the shaft.
https://2ndgenautoparts.com
Ignore the hub in attached photo - they substituted the correct 8-hole hub in my kit.
Any best practices for cleaning up the aluminum pump?
Thanks!
