Old 03-21-2025, 06:45 AM
Shifted302 Shifted302 is offline
Default 66 L72 pullies
Looking for crank and waterpump pullies for a 66 L72 biscayne
You spend dollar's to go fast, I spend pennies to beat you with a 4 gear
Old 03-21-2025, 02:33 PM
STEFS STEFS is offline
Yenko Premier Member
Do u have part numbers
Old 03-22-2025, 03:57 PM
Unfortunately I do not
Old 03-22-2025, 08:06 PM
Best confirm but if any help, most online info notes ‘66 L72 Pulley #’s as list below from this link…
https://www.detroitautomotiverestora...7-425hp-engine
‘66 L72…
To complete the L72 engine package, below are the other unique parts for this engine (Some parts like the 3872444 Bell Housing are not shown because they were shared with the L35 396 and the L36 427/390HP engines):
Distributor (non-transistorized) - 1111100
Carburetor Intake Gasket - 3881847
Air Cleaner, Dual Snorkel - 6421970
Air Cleaner Decal, 427 Flag - 3874904
Air Cleaner Decal, Horsepower Banner, TurboJet 425HP - 3880870
Air Cleaner Stud - 3869954
Air Cleaner Vent Elbow - 3868842
Air Cleaner Vent Hose - 3846122
Flame Arrestor - 3849856
Camshaft - 3863143
Pistons (11.0:1) - Standard - 3888342 - 0.030 over - 3888344
Crankshaft - 3869952, Casting # 6223
Oil Pump - 3876868 ( Replaced by 3904826)
Oil Pump Drive Shaft - 3865886
Vacuum Advance - 1115360
Vacuum Advance Tube - 3877640
Intake Manifold Gasket Kit - 3955527 (for Rectangular Port Heads)
8" Harmonic Balancer - 3860010
Timing Chain Cover - 3975941
Fuel Pump - 6416459 (AC Number 40358)
Fuel Lines - Pump to Tee: 3886151, Tee Block: 3886153, From Tee to Carb: 3886152
Valve Covers (Drippers) - 3877631 (LH), 3877632 (RH)
PCV Valve - 6423438 (CV691C)
PCV Hose - 3871298
PCV Hose Clip (at Base of Carb) - 3846117
Choke Coil - 3887148
Choke Rod - 3885070
Idler Pulley Bracket - 3878226
Water Pump Pulley - 3864480
Crank Pulley - 3869978 (casting number)
Alternator Pulley - 3844100
Alternator Fan - 3843346
Exhaust Pipe (LH) - 3866523
Exhaust Pipe (RH) - 3866524
Muffler (LH) - 3928215
Muffler (RH) - 3884800
Tailpipe (LH) - 3883697
Tailpipe (RH) - 3883698
Tailpipe Hanger (LH) - 3883693
Tailpipe Hanger (RH) - 3883694
Tailpipe Clamps - 1368195
7000 Tachometer (6000 Red Line)- 6412549
If your L72 had Transistorized Ignition, here are some additional parts that are required
7000 Tachometer (6000 Red Line) - 6412572
Distributor - 1111074
T.I. Module - 1115005
T.I. Coil - 1115210
42 Amp Alternator - 1100696
T.I. Harnesses, Main: 2988218, Extension: 6287841, Ignition Lead: 2986913
L_e_e (03-25-2025)
Old 03-22-2025, 10:57 PM
Thank you very much for the information
Old 03-23-2025, 12:21 AM
That crank pulley is wrong, I need the one that's a 2 groove
The Following User Says Thank You to Shifted302 For This Useful Post:
PeteLeathersac (03-23-2025)
Old 03-23-2025, 01:14 AM
hiperf69 hiperf69 is online now
No, I believe he is correct.
That motor came with the 3groove #3869978 pulley.
I screwed up last weekend at a swapmeet and walked right by one and forgot to go back before I left.
Joe
Old 03-23-2025, 02:41 AM
LT1vette LT1vette is offline
WP pulley...480 is correct ( superceeds this # 3906656 7.25"
Crank pulley....978 is correct, has 3 grooves. (make sure it is the correct diameter)BUT if you are not going to install the idler pulley and bracket, use the 2 groove belt pulley.
NOW, you also have to get the correct PS bracket and pulley, also the alternator bracket and pulley, along with the correct water pump.
It will take you awhile, some trial and error needed. Unless you have a non-numbers matching car, then you can substitute some other pulley numbers.
*** NOTE...get the correct measurements for each pulley, most are listed in the parts book.
PM if you need more help
Old 03-23-2025, 03:26 PM
outlawperformance outlawperformance is offline
I have a 1966 Biscayne L72 car with the idler pulley. The crank pulley is a 3 groove cast iron and the power steering pulley is cast also. I'm not saying this is correct but sure looks period correct.
Old 03-25-2025, 08:19 PM
mssl72's Avatar
mssl72 mssl72 is offline
It's a 3 groove pulley. That provided list is from Leigh Scotts website!
He is the '66 Full Size Chevy Guru. Super guy too!!
If the car your getting parts for isn't an original L72, then yes, feel free to substitute.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
