#91
Re: Mega thread with multiple items for sale
The strap listed above is also correct for 67 and 68 Camaros to hold the washer hose to the fender well. Also correct for 69 Camaro 396 and 427 holding the negative battery cable to the inner fender
#92
69-74 Camaro Firebird front brake line clamp + ((ER)) Bolt. Restored EXCELLENT CONDITION 3952757 c stamped. as nice as you will find $65 shipped to the lower 48
#93
69-72 heater hose - alternator bracket mounting clip and bolt for Camaros Chevelles Novas and Impalas. Both big and small block. Restored in excellent pit free condition AS stamp on the bracket E head marking on the bolt bracket has been glass beaded and repainted, Bolt has been stripped tapped and replated. Ready to install on your freshly restored car. Some cars used a 5/16 bolt some cars used a quarter inch bolt let me know your application and I will supply the correct bolt. $60 shipped to the lower 48 I have 2 restored clips and bolts available
#94
Big block lower alternator pivot bolt lock nut and flat washer. For short water pump applications. 65 thru 74 Corvette 65 through 68 Nova Impala Camaro Chevelle. f in a circle head marking bolt and dimple lock nut. They do not reproduce this bolt with this head marking or the locking style nut
. Very nice very good condition SOLD $60 shipped to the lower 48 SOLD |
#95
Rich, that would look pretty under my alternator. I'll take it. Jeff
#96
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Enoch</div><div class="ubbcode-body">
Camaro Chevelle Nova Firebird GTO Impala Idler arm 2 frame mounting bolts, thick oversized flat washers + acorn locking nuts. 40 per set shipped to the lower 48. WB 4 sets available CH 2 sets available </div></div> Do you have any with an "A" Head Marking? If so I'll take them. Thanxs Dave
67 Z/28 Butternut Yellow 69 Z/28 Rally Green 69 Z11 Pace Car (2) 69 RS/Z28 Lemans Blue / Olympic Gold 2010 2SS RS Aqua Blue 68 Z/28 Lemans Blue C7 Corvette 68 SS Lemans Blue |
#97
Jeff, thanks I'll send you an invoice for the alternator pivot bolt and nut.
Dave let me check and see if I have any a head marking idler arm bolts. I will let you know thanks rich. |
#98
Complete set of ac evaporator box to firewall mounting hardware for Camaros Chevelles Novas impalas GTOs Firebirds 442 Cutlass. Included are 6 s head marking 1/4 - 14 self tapping bolts that mount the box and 2 C stamped mounting pal nuts. They don't reproduce this bolts and nuts with these markings. $80 shipped to the lower 48 |
#99
Corvette Camaro Chevelle Nova Impala GTO Firebird 442 Cutlass . Ac evaporator BOX 1/2 mounting bolts. These mount the two halves of the box together. C head marking, 3/8 hex head. Recessed flanged head. 1/4-14 thread w/self tapping notch cut into the end. They do not reproduce this style of bolt. 45 shipped to the lower 48. |
#100
Smog pump pulley bolts RBW and diverter valve bolts RSC. For big and small block cars. Excellent unrestored condition $80 a set shipped to the lower 48 3 sets available |
