Old 09-10-2019, 07:50 PM
Enoch Enoch is offline
Banned
Next up two more original assembly line installed small-block and big-block brass oil line compression fitting and bushings. Both bushings have the Weatherhead stamping on them. Very rare pieces. $40 each ppff (X)
Old 09-10-2019, 07:53 PM
Banned
Next up 4 very nice small block tall oil pressure line to block fittings. Three of them are pH stamped, one of them has no markings. 3 that are stamped are $35 each and one with no markings is $20. Very nice, very hard to find originals with correct era stampings. (X)
Old 09-10-2019, 07:57 PM
Banned
Next up are two original Swedge lock bushing fittings for the oil line.
The bushing on the left is NOS and has Weatherhead stamping. Also the correct 5/16 hex fitting is NOS. That setup is $40. Ppff (X)
The bushing on the right has no stamping but is an assembly line piece and comes with an NOS 5/16 hex fitting. $30 **********SOLD**********
Old 09-10-2019, 08:01 PM
Banned
Next up 65 66 early 67 396 427 brass 90 degree fuel pump elbow, 3/8 line. Two of them weather head stamped assembly line pieces $35 each; one NOS Eaton stamped $35. Ppff (X)
Old 09-10-2019, 08:05 PM
Banned
B&N stamped, rubber vulcanized oil line clip and RBW head marking bolt that attaches to the driver side rear head boss. This clip and bolt attaches the oil lines as it goes down to the fitting. Very nice unrestored originals. $35 ppff (X)
************SOLD ************
Old 09-10-2019, 08:07 PM
Banned
Original tach-drive distributor brass coupler $20 (X)
Old 09-10-2019, 08:33 PM
Banned
1970 and up 396, 427, 454 front engine lift hook. Part number 3969829 stamped on rear. $80
************SOLD************
Old 09-10-2019, 08:58 PM
Banned
NOS set of 3 tri-power carbs gaskets. These are originals from GM about 30 years ago. Correct composite material with printing. 3 gaskets per set $40. (X)
Old 09-12-2019, 05:01 PM
Banned
396 427 454 crankcase elbow breather. This is an original piece I took off a car many years ago and replated it. $20. ppff (X)
Old 09-14-2019, 08:23 PM
Banned
65 through 74 Corvette and 65 through 68 Camaro Chevelle Nova short water pump big block alternator mounting bracket. Excellent original condition. $55 shipped to the lower 48 if paid with PayPal friends and family.
