Old 05-16-2022, 07:24 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Thanks. MEK
scuncio (05-16-2022)
Old 05-16-2022, 09:04 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
^ MEK to remove spray bomb black off a fan shroud?
If so, I’m going to try that too. Thanks!
cook_dw (05-18-2022)
Old 05-17-2022, 01:00 AM
cook_dw's Avatar
They no longer make MEK. They have what is called MEK substitute. I have not tried it to date but will soon as I am now out of all my old MEK stockpile.
Old 05-18-2022, 03:58 AM
BJCHEV396's Avatar
Great work Darrell.Very informative.Keep up the good work!
Old 05-24-2022, 03:49 PM
cook_dw's Avatar
Photos 281 - 282 - Original calipers before teardown and cleaning. Cleaning was like many of my previous cleanings. Citrus degreaser then soaking in Evaporust. Then coat with RPM or Rust Veto or alike. Currently I am using up my RPM as it seems to work very well.
Photo 283 - Results of bracket line brackets and lines after cleaning. These are original finishes. Nothing was rezinc'd or refinished.
Photos 284 - 286 - Calipers after cleaning. I did have to buy new pad pins as the originals were MIA as noted in previous photo as someone had installed a nail in place of one of them in the cars past. I will have to send these out as 2 of the 8 bores are pitted so stainless sleeves will be needed. Note black paint still present on the rears of the calipers.
The Following 10 Users Say Thank You to cook_dw For This Useful Post:
1967Z28 (05-24-2022), 67since67 (05-24-2022), Dave Rifkin (05-24-2022), dykstra (11-30-2022), jbtech (05-25-2022), L72Chevelle (05-27-2022), napa68 (05-24-2022), PeteLeathersac (05-24-2022), RPOLS3 (06-03-2022), X66 714 (05-24-2022)
Old 05-24-2022, 05:30 PM
black69 black69 is offline
enjoying this preservation thread, I am kinda in the same boat on some things with my 68 z . I will soon looking at my brakes and getting tips to preserve here.
The Following User Says Thank You to black69 For This Useful Post:
cook_dw (05-24-2022)
Old 05-24-2022, 09:10 PM
SMS SMS is offline
Who are you using to sleeve the calipers?
Old 05-24-2022, 09:37 PM
cook_dw's Avatar
Haven’t decided. White Post Restorations currently has the master cylinder (they received it on 5/6) and I’m waiting for it to come back. Depending on turn around I’ll probably use them but it’s $320 per caliper (4 piston) plus shipping. I’ve used them in the past with good results so I have no experience with any other company. Maybe someone else can chime in on their experiences with someone else?
SMS (05-25-2022)
Old 05-24-2022, 10:37 PM
scuncio scuncio is offline
Amazing those brake line brackets came out so mint.
cook_dw (05-25-2022)
Old 11-29-2022, 04:35 PM
cook_dw's Avatar
Figured I'd update this thread since its been a few months.
Photo 287 - 289 - Finally got the master back from White Post and I assembled the components.
Next I decided to bounce back and clean up the cowl panel & wiper transmission.
Photo 290 - 291 - Panel & linkage before cleaning.
Photo 292 - 295 - After cleaning, Meguiars #7, wet sanding with 2K, Meguiars 105 & 205, and Meguiars #7 again.
Photo 296 - 298 - screws, squirters and cowl seal added after they were cleaned.
Photo 299 - 302 - Lastly are details on the wiper transmission linkage after cleaning.
The Following 4 Users Say Thank You to cook_dw For This Useful Post:
1967Z28 (11-29-2022), dykstra (11-30-2022), olredalert (11-29-2022), Steve Shauger (12-01-2022)
