Old 03-20-2006, 09:00 PM
BillD BillD is online now
Default Vintage Wheels
I plan to mount up an old set of Torq Thrust D's this week. Should these be run with tubes? I seem to remember these being tubeless back in the day, but also remember them being leakers. Any suggestions?
Attachments - The Supercar Registry 320047-tn_Z28RS.jpg 320038-tn_68L30Camaro(11).jpg 212481-Creitzwheel.jpg 207571-tn_DSC02409.JPG
Old 03-20-2006, 11:47 PM
TDW TDW is offline
Default Re: Vintage Wheels
Bill..I put a set of 1966 vintage International Dragmasters on my 68 a couple of years ago. They only lose about 10 lbs setting in the garage all year. Not bad at all. Tubeless tires.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 03-21-2006, 05:02 AM
Belair62 Belair62 is offline
Tubeless...no better looking wheel....
Old 03-24-2006, 08:02 PM
It's never easy!!!!!! I was warned about valve stems, any suggestions as to what to use? A standard stem does not work and while I have found some that will work I have a choice between a stem that looks like it belongs a on Honda Civic with 20" rims or a stem that looks like it belongs on a Kenworth truck. I know its getting a little nutty when you worry about what the valve stems look like............but that is the nature of my mental illness with these old junks
Old 03-24-2006, 10:11 PM
427TJ's Avatar
427TJ 427TJ is offline
I've used rubber as well as metal stems on both sets of my TT's and had no problems. Ran them tubeless. Yeah, you gotta' check the tire pressure but you gotta' do that anyway. I don't recall any obvious leak/seep problems. Make sure the stem holes don't have any burrs or hairline stress cracks.
Old 03-25-2006, 01:29 AM
You should be able to get some normal looking bolt thru crome stems...
Old 11-04-2006, 09:42 PM
Has anyone seen the Build sheet for an LS6 build in Arlington on Ebay ? I've always heard that there is no credible/ proven sheet from any LS6 Arlington cars ? any thoughts ? Item # 130043460578
Old 02-18-2008, 06:44 AM
427freak 427freak is offline
You have to Love those 5 spokes. I run them any chance I get.
Dana
MBTMF
Old 02-18-2008, 06:51 AM
ORIGLS6 ORIGLS6 is offline
I'm guessing 14 x 6 TTDs on the front? Maybe 15 x 7s on the rear?
Old 02-18-2008, 06:53 AM
15X6 D's on front. Good guess though...
Dana
MBTMF
