Got the intake back from the machine shop and dry fitted and then did another fit with the NOS steel gasket.
![]() Observations of original W30 cars show no paint on the heads on either side of the intake and none on the steel gasket. It is believed a template was used to cover the intake and other items like the hook, thermostat housing and other small parts were painted as they lay on top of the template. I have seen engines with no paint on these items to some that had a partial coat. I opted for the latter and painted about 3/4 of the surface area of these parts. ![]() More Nos parts used here. Balancer Lower pully Starter bracket Fuel pump Temp sending unit Coil bracket Manifolds were media blaster and a graphite was applied, burnished with 000 steel wool, one more coat of graphite applied and then heated with a heat gun to cure the graphite. Final look is fresh cast iron.
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com |
The Following 3 Users Say Thank You to Canuck For This Useful Post: | ||
Hit EBay and grab 6 NOS goodies!!
Ryan W31.
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
Looks great Paul!
Just read this entire thread, you are a patient man! My ADD would be hitting a high point 6 years ago!
Love the story, thx for sharing!! |
![]() Quote:
Congrats on buying the car. I met Merlin a couple times, and he was very close friends with a good friend of mine. He was a terrific guy... sadly, gone before his time. Last edited by L78M22Rag; 04-12-2021 at 04:18 PM. |
You might be referring to Al Shannon.
It looks so clean! I can see the progress with this build, I can't wait to see how it goes. Btw, I feel like the HD wheels Spinout series will add style to that classic car.
over the past 18 months the body has been transformed from a rust bucket ,to a shell and back to a body,piece by piece. My body guy has painstakingly duplicated dimples, changed round nuts to square ones and rebuilt parts to their factory correct locations. Here is a series of photos
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() panels were brought to bare metal,ecoated,proved blocked and ready for install. The copper is weld through primer. ![]() ![]() ![]() ![]()
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com Last edited by Canuck; 04-30-2021 at 04:57 PM. |
The Following 5 Users Say Thank You to Canuck For This Useful Post: | ||
olredalert (04-30-2021), PeteLeathersac (04-30-2021), RPOLS3 (05-08-2021), ScottG (06-03-2021), Xplantdad (04-30-2021) |
Lots of progress over the summer months. As mark was progressing on the body,I finished getting the engine ready. Some delays were caused by the arrival of some nos parts I had to ad.
NOS oil pan cleaned and ready for paint and install. ![]() Lower part of pan was covered with flat clear and dusted in Olds Blue to replicate factory minimal approach to paint. ![]() Nos short block with factory markings. Paint daubs indicate bearing clearances. ![]() Engine pre dressed to check For fit and checking torque. ![]() Loaded into truck for delivery to resto shop. ![]() June 15, engine and trans on restored frame ready for body drop. ![]()
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com Last edited by Canuck; 09-20-2021 at 10:50 PM. |
454_Malibu (09-20-2021), CanCOPO (09-20-2021), olredalert (09-21-2021), Tracker1 (09-22-2021), Xplantdad (09-22-2021) |
A surprise development on the history of my car surfaced on FB Friday. The attached photo was posted by a fellow in Alberta of a 442 he owned in the late 70’s. After a few messages We were able to determine that this is the car I am restoring.
His info stated he bought the car through an Auto Trader style ad in 1977 and the car had come from Halifax. He kept the car for a few years and sold it in 1980. He stated the car “ had returned to the earth in a wrecking yard in Blackie,Alberta” Well it didn’t return to the earth as it was purchased from that wrecking yard in the early 80’s. The car had a hard life as it had a front end hit as well as a motor change before I bought it. ![]() Insurance card from 1979. ![]()
The Following 8 Users Say Thank You to Canuck For This Useful Post: | ||
carnut4life (09-25-2021), Crush (09-25-2021), L_e_e (09-25-2021), olredalert (09-25-2021), PeteLeathersac (10-11-2021), Sportwagon400 (09-26-2021), Steve Shauger (09-25-2021), Xplantdad (09-28-2021) |
