#101
Not on the brakes - thanks for asking. I tried smashing the pedal several times on Sunday with no luck so instead I started cleaning the car up since it has been sitting for 18 months. Adjusted the hood latch, did some paint touch ups, installed a correct alternator/smog pump belt from Quanta, washed the car cover. Haven't given up yet, just trying to be productive in other areas.
The Following User Says Thank You to RPOLS3 For This Useful Post: | ||
napa68 (03-01-2022) |
#102
![]() Quote:
The Following User Says Thank You to 67since67 For This Useful Post: | ||
RPOLS3 (03-01-2022) |
#103
----Yup, Bill! That's my mantra. Walk away and settle down. Don't sweat the small stuff, and it's almost all small stuff!......Bill S
The Following 4 Users Say Thank You to olredalert For This Useful Post: | ||
#104
I bought this tool and I'm told it should will re-center the valve in the casting without needing to remove the casting from the frame, just remove the pressure switch (may be harder than it sounds) and screw this in its place. Once valve is centered I think you can leave it in while bleeding to make sure it does not move due to pressure differences while bleeding.
I would have thought you would need to use a small screwdriver or pick to move the valve prior to inserting this but maybe not? |
#105
I believe the piston is tapered inside.
#106
Who rebuilt your valve?
2023 Silverado (last GM vehicle I am buying!) 2017 impala (wife’s car) 1970 Raylle 350 post coupe (sold) (5 yrs in bodyshop)had enough!!! 1971 442 W 30 holiday coupe automatic . |
#107
#109
Hopefully...
I would put a mild radius on the very end, so it isn't such a sharp edge. Yes, leave it in until done bleeding.
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
RPOLS3 (03-03-2022) |
