![]() Quote:
I believe built in KY but I don't recall mfg name. |
With these haulers you can be loaded in 10 minutes and rolling. I hauled this bubbletop to Burlson Texas and got an honest 13 mpg running 3:73 gears, 454 with overdrive.
The Following 3 Users Say Thank You to mprice For This Useful Post: | ||
Hodges Custom Haulers still makes em in Kentucky,but have a huge back log till June of next year for making other vehicles as well.. http://www.hodgescustomhaulers.com/enclosed_beds.html
love the way this Duramax Denali pulls the trailer
The Following 11 Users Say Thank You to bergy For This Useful Post: | ||
Big Block Bill (09-10-2022), big gear head (09-09-2022), dustinm (09-08-2022), dykstra (09-09-2022), markinnaples (09-08-2022), napa68 (09-08-2022), olredalert (09-08-2022), RPOLS3 (09-11-2022), SMS (09-09-2022), Too Many Projects (09-08-2022), YenkoYS-199Stinger (10-18-2022) |
Those Duramax's are torque monsters and I'd like one for distance hauling to pull the trailers, but otherwise, I have no need/want for a 2500/3500 truck.
For local stuff, I still have my roll back and trailer. ![]()
The Following 11 Users Say Thank You to Too Many Projects For This Useful Post: | ||
69 Post Sedan (01-10-2023), bergy (09-08-2022), big gear head (09-09-2022), dustinm (09-09-2022), dykstra (09-09-2022), earntaz (09-08-2022), markinnaples (09-08-2022), olredalert (09-21-2022), RPOLS3 (09-11-2022), SMS (09-09-2022), YenkoYS-199Stinger (10-18-2022) |
2005 Duramax LLY. I bought this truck in 2018 for my new daily driver and was the best investment I've ever made. I was very lucky to find this truck, as it only had 88,000 miles on it when I bought it, it had never been modified and it was optioned exactly like I wanted. It's a great truck, super comfortable and has allowed me to whatever I've needed in terms of moving vehicles over the years. Low maintenance costs, no truck payment....just put fuel in it, pay the insurance and drive it. I'm happy with that. No truck payment = muscle car money, haha!
Andy 1967 Camaro 406 4 speed 1969 C/10 383 5 speed 1969 D300 318 4 speed 1969 Super Bee 383 4 speed 1972 K/5 350 Turbo 350 1972 Duster 340 727 1974 'Cuda 340 4 speed |
The Following 10 Users Say Thank You to Andy For This Useful Post: | ||
69M22Z (09-21-2022), dustinm (09-22-2022), dykstra (09-23-2022), Keith Seymore (01-09-2023), L_e_e (09-22-2022), markinnaples (10-18-2022), MosportGreen66 (09-23-2022), olredalert (09-21-2022), PeteLeathersac (10-19-2022), YenkoYS-199Stinger (10-18-2022) |
The tower and the Towed
2021 Chevrolet Suburban HighCountry 2022 Airstream Globetrotter 30 2005 Wells Cargo 24 ![]() ![]() ![]() ![]()
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, completed 68 Camaro Z28,Corvette Bronze,Houndstooth 2016 Porsche Carerra Cab and 2021 C63S AMG ,modern fun. www.vancouverclassiccars.com Last edited by Canuck; 10-19-2022 at 04:12 AM. |
The Following 7 Users Say Thank You to Canuck For This Useful Post: | ||
69M22Z (01-10-2023), dykstra (10-19-2022), markinnaples (10-19-2022), olredalert (10-19-2022), RPOLS3 (10-20-2022), SMS (10-19-2022), YenkoYS-199Stinger (01-10-2023) |
Just a quick follow-up if anyone's interested;
I got the 572 for Yeti on the dyno a week or so back. It did better than I'd expected actually in regards to HP, but due to the fact that I couldn't install the headers the engine needed on the dyno due to space constraints, we wound up leaving quite a bit of low end torque on the table. Past dyno experience assures me the power is indeed there with the correct exhaust, I just don't have a dyno sheet saying so. I got hung up waiting on a new carb from Holley, so the dyno shop made an initial pull with their dyno mule modified 750 which was WAY too small for this application. It made over 600 lb.ft from 3500-4900 peaking at 630 @ 4300 and 563 HP @ 5000 when the pull was stopped. I finally got the new Holley in, plus I pulled the 1000HP I built for the 496 in my Chevelle and took it with me to the dyno. With nothing more than the swap to my 1000HP, power increased dramatically everywhere. The #'s from that pull are shown below. The 1000HP was running pretty lean at roughly 14-1 @ WOT, so there was still quite a bit of power to be had there as well. Next was my new 870 Holley, but it was deep into the 14-1 range at roll-in out of the box, so we aborted the pull and took lunch. I bumped the jetting up 5 sizes all the way around which brought air/fuel ratios down to the mid 13's which was still lean, but safe. We did 2 more pulls experimenting with timing, finding a touch of power dropping timing down from an initial 34°, then 36°, then finally at 32°. Next I removed the 1.8 intake rockers and swapped on some 1.7's which cost a few HP up top but picked up a little power down low, which was the entire focus of this project. BTW, we tried to tug the engine down into the 2000 RPM range but the dyno couldn't pull it down any lower than 3400 and hold it there. If you'll notice the "sag" in torque at the hit, that's 100% the result of not having the correct size headers & collectors in place. I am 100% confident with the correct exhaust on it the engine will make 700+ lb.ft. torque--I don't really care about peak HP, but since it's already at nearly 600 @ 5200, that should be ample. I was only anticipating 525-550 HP. The engine only has 8.8-1 compression and all testing was done on 89 octane pump gas, and the engine will idle with a pleasant but mild lope at 750 rpm. Yeti is currently in the shop getting the howling 4.10 gears removed and replaced with a new set of 3.54 gears and a Lock-Rite differential. Hopefully I'll be able to get the 572 in the truck sooner than later as the existing 454 is running OK but has alarmingly low oil pressure. That should be enough to be able to haul anything I need to tow. Last edited by VintageMusclecar; 11-23-2022 at 11:37 PM. |
The Following 6 Users Say Thank You to VintageMusclecar For This Useful Post: | ||
dykstra (11-23-2022), olredalert (01-09-2023), PeteLeathersac (01-09-2023), RPOLS3 (11-27-2022), SMS (12-01-2022), YenkoYS-199Stinger (01-10-2023) |
just got my new one in. ordered it first part of august. first dually ive had that wasnt a king ranch since 2008. wanted one but they wouldnt accept the order for a limited or king ranch so i ordered this one with lariat ultimate and a few other packages and then ordered a handful of individual options to get it loaded up with all the heat/cool seats, heated steering wheel, enhanced camera, self brake, lane change etc. big screen on the dash, also got the camper special pkg which added a few options. one option i absolutely did not click was the sunroof. the last 3 or 4 duallys i have got sunroofs and everyone of them broke. first trip i got 19.8 mpg. not bad for a big heavy 4wd dually.
The Following 8 Users Say Thank You to muscle_collector For This Useful Post: | ||
69M22Z (01-10-2023), dykstra (11-24-2022), flyingn (01-11-2023), markinnaples (11-30-2022), olredalert (01-09-2023), RPOLS3 (11-27-2022), SMS (12-01-2022), YenkoYS-199Stinger (01-10-2023) |
A couple updates to the tow topic. Since my last shot of the Chaparral project I decided to try to clean the interior walls rather than insulate and cover them. Glad I did. I found that some stuff called LA Awesome Cleaner took away the 30 years of racing soot. Tried NAPA Alumabright on the ramp door and that will be good to use inside on the floor when it warms up.
The Following 4 Users Say Thank You to SMS For This Useful Post: | ||
dykstra (01-09-2023), muscle_collector (01-09-2023), olredalert (01-09-2023), YenkoYS-199Stinger (01-10-2023) |
