Old 06-09-2008, 11:53 PM
jeff-san jeff-san is offline
Default Re: 1968 CY Trans details
I was told the 426 was a Julian date started Jan 1 of 68 so 426 was the end of Feb '69. I guess a bunch of guys possibly have CX tranny's with 427 build dates...very cool.
Old 06-10-2008, 04:03 AM
Jeff,
Here is my CX ID tag. Odd that yours is one below 427 and
mine is one below 396........
Steve
Old 09-15-2008, 06:25 AM
Default Re: CY & CX 400THM: differences & similarities
For the year 1970:
*TH400 CY Trans. was coded for the LS6 Chevelle,& Corvette LS5.
Higher-shift point and stronger bands & springs.I believe a thicker shaft as well?
*TH400 CW Trans. was coded for the L78 Chevelle-Nova-Camaro,& LT-1 Camaro-Nova.
*TH400 CR & CS Trans. was coded for the LS5 Chevelle-Monte Carlo,& Corvette w/Transitorizied Ignition.
*TH400 CF Trans. was coded for the L34 Chevelle-Camaro-Nova.
*TH400 CK Trans. was coded for the 300HP 350cid Corvette.
Would a 69 Chevelle SS L-78 be a CX code like the Camaro?
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 09-15-2008, 07:11 AM
Yes,as they too had a higher shift point.
Old 09-15-2008, 07:05 PM
Thank you.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 12-08-2008, 12:01 AM
Camaroresto Camaroresto is offline
What would this tranny be from...
tag CA 66 20597 with 286 stamped above that line.
Bryan Paschal
1969 Cortez Silver Z/28
1969 Cortez Silver SS396 convertible
1971 Copper RS Z/28
Old 12-08-2008, 12:20 AM
Any 1966 Impala-Belair-Biscayne-Caprice with a 396/325HP & TH400,assembled after October 13th,1965.
Old 02-13-2009, 09:08 PM
Couple questions>
1. What trans codes are correct for '69 COPOs with automatics? Are they different for different models i.e. Camaro and Nova?
2. In '69 are the CX and CY codes used on all solid lifter motors (with automatic trans)?
3. Do all TH400s in '69 have partial VINS stamped on them?
Thanks!
Old 02-13-2009, 09:20 PM
deuce-less deuce-less is offline
69 L-78 nova CX trans
Old 02-13-2009, 09:21 PM
vin stamped on passenger side frt flange 4 times
