Old 04-18-2021, 03:41 AM
GotGrunt's Avatar
GotGrunt GotGrunt is offline
Awesome! What happened to the rear end? Is it a BE?
Old 04-18-2021, 01:04 PM
PapsMaro PapsMaro is offline
I have the rear end. Someone tried to steal it by ripping it out a few years ago so we had to remove it completely.
Old 04-18-2021, 01:23 PM
BLACKLS5 BLACKLS5 is offline
Great to see this one on it's way to being saved. I Like the 'Blue yummy' sitting on the header panel after a hard days work.
The Following 2 Users Say Thank You to BLACKLS5 For This Useful Post:
dykstra (04-18-2021), PapsMaro (04-18-2021)
  #114
Old 04-18-2021, 01:42 PM
Rumbleguts396 Rumbleguts396 is offline
This is Awesome !!!!! ROB
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
The Following User Says Thank You to Rumbleguts396 For This Useful Post:
  #115
Old 04-18-2021, 06:53 PM
Pro Stock John's Avatar
Congrats on your progress!
The Following User Says Thank You to Pro Stock John For This Useful Post:
  #116
Old 04-18-2021, 10:31 PM
Got the rear end home, trans, drive shaft, and maybe the bell housing? I’m not sure what it is or if it’s original. I think it is but not positive. How do I confirm that it is the original rear end?
The Following User Says Thank You to PapsMaro For This Useful Post:
Rumbleguts396 (04-18-2021)
  #117
Old 04-18-2021, 10:43 PM
R68GTO R68GTO is offline
Looks like an M21 Transmission. Check the trans for VIN stamping. On the rear end, look on the passenger side tube on the section that faces the front of the car. There should be a stamp there for both the model (you're looking for BE) and the date of manufacture. Be careful in uncovering the stamp, don't use anything abrasive like sandpaper, it will mar the stamping. Clean it up gently and submit a few photos. Gotta be exciting for you, hell, I'm excited!
  #118
Old 04-18-2021, 11:57 PM
[QUOTE=R68GTO;1545372]Looks like an M21 Transmission. Check the trans for VIN stamping. On the rear end, look on the passenger side tube on the section that faces the front of the car. There should be a stamp there for both the model (you're looking for BE) and the date of manufacture. Be careful in uncovering the stamp, don't use anything abrasive like sandpaper, it will mar the stamping. Clean it up gently and submit a few photos. Gotta be exciting for you, hell, I'm excited![/QUOTE
What do you recommend I use to clean it with? Just a brush? Thank you for the knowledge also!! I’m beyond excited!
Old 04-19-2021, 12:09 AM
It looks like it's mostly rust. I would use a wire brush with a rust penetrant to loosen it. Once you have the rust cleaned as well as possible, it may still take light sanding with 400 and water as a lubricant to reveal the stamping. You just don't want to use anything aggressive for sanding.
The stampings for the trans should be on top. It will have a coded assembly date and should have the last 6 numbers of the vin too. They can be almost anywhere, but the top was the most common, usually on the main case, but sometimes on the midplate.
Old 04-19-2021, 12:19 AM
Hard to see
