#111
Well I suppose all those clutch dumps over the years cause a little stress here and there.
The brace from the firewall to the lower middle dash was fatigued and torn away. There was actually a small piece missing which I fabbed a replacement piece and welded in. Top of this brace is broken loose and had been machine wired in place. A little easier to see from this side I did have to grind it a little afterwards to clear the defrost duct.
68 Acadian SS-350 auto/AC driver 70 Nova SS-396/375HP Bench Stick 72 Nova SS-350 5sp Mini Tubbed 67 Chevelle Conv. SS-427 clone 70 Chevelle SS-454 LS-5 M-22 |
#112
I love L78 Nova's I like this one just browsed whole tread and when I saw you fixing the jacking point I remembered 11-12 years ago I bought a 69 nova 4 door subframe at pick N pull (actually got alot of stuff off that) because it was a 6 cyl it had never been jacked up there - it was beautiful and I had no need for it but it needed saved! little Nova trivia is 6 cyl cars did not have sway bars the mount holes were pierced but not threaded.
I recently bought my blue golf ball - a 69 Elcamino that needs a roof and right quarter from a little Texas hail and reading through this gives me some confidence of tackling it myself as I've never done much bodywork but why not try? thanks for sharing your car
69 RS/Z 302 VE3 Daytona 69 Chevelle SS 396 375 69 T/A clone LS6/6 speed 90 Formula 350 Last edited by Zman1969; 03-16-2022 at 04:44 PM. |
The Following 3 Users Say Thank You to Zman1969 For This Useful Post: | ||
#113
sorry double posted
69 RS/Z 302 VE3 Daytona 69 Chevelle SS 396 375 69 T/A clone LS6/6 speed 90 Formula 350 Last edited by Zman1969; 03-16-2022 at 01:54 PM. Reason: double |
#114
That is some Nasty Hail !! Texas sized for sure.
Time and patience is key, and I have some friends in the industry to help with answers when I'm stumped. Good luck with the Camino. Gary
The Following User Says Thank You to L78_Nova For This Useful Post: | ||
Zman1969 (03-16-2022) |
#115
You might try looking for a paintless dent removal (PDR) guy to look at repairing that. It is truly amazing what they can do with damage that appears to be only repairable by panel replacement or filler. You can save what is presumably the original sheet metal along with being faster and less expensive.
The Following 3 Users Say Thank You to RPOLS3 For This Useful Post: | ||
#116
As the wire wheel stripping continued a few not-surprising pinholes were found along the lower Windshield flange. This is after picking at it pretty aggressively to find any soft spots.
Repaired this in two sections using patch pieces with a 90 degree break along the upper edge (trimmed to about 3.32" deep) to help minimize distortion (from welding) along the leading edge of the dash. If you look closely at the top edge you can see the radius where the patch panel was bent inward. Fitting the second patch And the finished repair
The Following 8 Users Say Thank You to L78_Nova For This Useful Post: | ||
big gear head (03-19-2022), chevyman0429 (03-18-2022), Dave Rifkin (03-19-2022), NorCam (03-19-2022), olredalert (03-19-2022), PeteLeathersac (03-19-2022), scuncio (03-19-2022), Xplantdad (03-19-2022) |
#117
Nice work.
And as GM called the foam that's under that top dash...it was referred to as planned obsolescence. Hard to find a 50 year old car now days that doesn't have this issue.
I like solid lifter cars, big cams and cars w/ 3 pedals in them. ![]() |
The Following 5 Users Say Thank You to NorCam For This Useful Post: | ||
L78_Nova (03-21-2022), PeteLeathersac (03-19-2022), ruralrte66 (03-19-2022), Ryan1969Chevelle (03-19-2022), scuncio (03-19-2022) |
#118
![]() Quote:
PS: I am loving the metal work in this build thread. One question, why not dip or blast the shell before doing all this amazing work? Wouldn’t it make it a hundred time easier? Certainly not criticizing, you are kicking ass!! Ryan W31
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
#119
![]() Quote:
Agree it would have been awesome to start with chemical dip but closest shop would be about 400 miles away and no local shops I would trust blasting the panels. Blasting the underbody is coming up shortly. Both quarters, front fenders and rear panel were NOS so easy to strip sand those. I guess just working on it in winters a little at a time over a couple years.. the stripping was not as bad. Yes the Novas also had the death foam in the rear wheel lips. They rusted out in only a few years when winter driven up here.
#120
While on the subject of stripping... A few photos of continued cleanup of the window channels.
Also continued cleanup of the underbody
RPOLS3 (03-21-2022) |
