Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 05-03-2010, 06:20 PM
77Z28 77Z28 is offline
Default Re: Picture Posting tutorial... test
[img][img]http://i774.photobucket.com/albums/y...n_IMG_6399.jpg[/img][/img]
What am I doing wrong that I can't see picture?
Old 05-03-2010, 07:13 PM
ORIGLS6 ORIGLS6 is offline
You've doubled-up. Remove the first "[img]" and the last "[/img]" and you'll get this.
Old 05-03-2010, 09:03 PM
Thanks sooo much!! Now I know how to do it!!!!
Old 09-17-2010, 01:44 PM
Atuckman Atuckman is offline
did this work
Old 09-17-2010, 03:16 PM
Yep!
Old 09-17-2010, 04:39 PM
bruce-
how did you make yours into a pic that is visible without having to click? mine came up as a file that requires clicking
Old 09-17-2010, 06:15 PM
You have to type [img] in front of & [/img] behind your picture text for it to appear automatically...
Example: [IMG]https://www.yenko.net/ubbthreads/ubbt...ame=before.jpg[/IMG
I purposely left off the last character to show you.
Old 09-17-2010, 07:11 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Atuckman</div><div class="ubbcode-body">bruce-
how did you make yours into a pic that is visible without having to click? mine came up as a file that requires clicking </div></div>
Even easier is to utilize the icons up above. The fourth one from the left is to enter an image. Once you've gone as far as loading your image up into the forum (like you did)...click on the picture link...then go to the address bar above and copy the location...once you have done that then click on the fourth button over from the left-like so-and paste the image location that you copied into the appropriate box:
Once you have done that...then it should look like this:
And it should work fine!
Old 07-12-2011, 01:48 PM
John's Avatar
John John is offline
...Has this process changed since Charley took over?
.... Do you still need to join ( 2 ) other websites
to upload photos? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 07-12-2011, 03:40 PM
You should be able to now upload them and they will show up.
