Old 12-03-2006, 10:46 PM
mssl72's Avatar
mssl72 mssl72 is offline
Default Re: Biscayne Resto Project
-----Im not sure if Im seeing things correctly, but it appears as though Jodys car has the bolt missing from that correct alternator bracket that would go thru to the intake. That would promote a bunch of twist as well!!!........Bill S
It's there, just barely peeking out from behind the upper radiator hose.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 12-03-2006, 11:06 PM
mssl72's Avatar
That Crank pulley is normal at #3869978 BO
I saw that the first 7 digit's were the correct part number, but it's the "BO" at the end of it that threw me. It looked like "80" on the end. The casting is a little different from mine.
Mark
Old 12-04-2006, 04:38 PM
Mark,,, My eyes were telling me that the hole was unfilled and I guess I was somewhat right. The hole I was looking at was unfilled, just was looking at the wrong hole. Thanks for pointing me in the right direction......Bill S
Old 12-05-2006, 03:03 AM
396/425blr 396/425blr is offline
kwhizz it looks like you know what you are doing here, just a heads up on the speedo cable. if you decide to go with the original type speedo cable that enters the trans on passenger side, don't forget to drill the 1" hole below the accel linkage. there is also a dimple on the passenger side of tunnel for the cable bracket to drill. also i found that i could not just change the tailshaft housing on mine because the speedo drive gear on the M-21 main shaft was not in the same place. not sure if that applies to all M-21 trans? dennis
Old 12-05-2006, 04:33 AM
to late to edit above post, i meant to say above accel linkage. between the accel shaft and master cyl. is that confusing enough dennis
Old 12-05-2006, 05:56 AM
kwhizz kwhizz is offline
After looking at Jody's Engine picture, I see what you are talking about.......Thanks
Ken
Old 12-12-2006, 01:52 AM
Got some parts in ..........Eric....Awsum "JOB" on the Carb
Also got a Engine Lift Stop Cable Unit that I bought on eBay.......
Ken
Old 12-14-2006, 03:20 AM
The Radio showed up today.....Perfectly stock appearing with AM-FM 4 channel 45 watts per channel...satelite ready...when you turn the radio on, it comes on in the FM mode....there is a LED that is installed in the back shield behind the needle.....when you tune in a FM station as the signal gets stronger it changes from Orange to Green.......if you want to listen to AM....you turn the Radio off and turn it immediately back on and it is now in the AM mode and the LED is Red........Tunes....
www.vintageautoradio.com
Ken
Old 12-14-2006, 03:31 AM
Also.......went to the Engine shop tonight and they had the engine torn down........Bearings Junk, Crank was .010 under....needs to go to .020 so I'll just replace it, cylinder walls tapered .005 , but the pistons appear fresh, probably a lousy honeing job.........the heads were oval port with a rectangular port aluminum manifold ......see where this is going......$$$$$$$$$$$
Getting a headache..........
Ken
Old 12-14-2006, 03:41 AM
With all that uninhibited torque thats gonna be taken place under that hood,are you considering a suspension mod of any kind?
Couldn't hurt to add a sway and her reinforced sisters.
They Call Him Devin
