Old 05-04-2011, 03:10 PM
Enoch Enoch is offline
Banned
Default Re: My '69 Z28 Find
James is correct. It is a Julian Calender dating system.
Rich
Old 05-04-2011, 06:33 PM
Jonesy's Avatar
Jonesy Jonesy is offline
295th (Oct 22) and 296th (Oct23) day of the year. That matches the timeframe of your car. The rotors are also stamped with ink just like that in yellow.
Old 05-04-2011, 07:33 PM
Thanks! Love to learn new stuff.
Old 05-04-2011, 07:44 PM
This just in.....
Don Stowers forwarded this photo of his 01B '69 Yenko Camaro. Date on the self-adjuster is consistent with the build date of the car. What a wonderful original car Don. Best of luck with the sale at Mecum!
Old 05-04-2011, 11:20 PM
MosportGreen66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mockingbird812</div><div class="ubbcode-body">This just in.....
</div></div>
Awesome! And I also see the original blue spring intact too, as my car has as well. Thanks for the help guys!
Old 05-05-2011, 01:29 AM
ORIGLS6 ORIGLS6 is offline
Dan,
Send me your mailing address. [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Old 05-05-2011, 01:32 AM
</div></div>
Well Geez. Since he was in there for the picture he coulda cleaned it up a little! [img]<<GRAEMLIN_URL>>/no.gif[/img] [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
[img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 05-05-2011, 01:41 AM
x  Baldwin  Motion's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ORIGLS6</div><div class="ubbcode-body">Dan,
Send me your mailing address. [img]<<GRAEMLIN_URL>>/wink.gif[/img] </div></div>
your box is STILL full!!!
Old 05-05-2011, 03:06 AM
L72COPO L72COPO is offline
That's original un-disturbed dirt and Nelson took the photo.
Don Stowers
66 GTO, Tri power, Fact. A/C, 4 speed
65 Corvette, L-76, Conv., Fact. A/C
63 Corvette SWC
Old 05-20-2011, 03:43 AM
Another update on the Z.
Front end is just about done! New lower ball joints, lower control arm bushings, idler arm, pitman arm, offset shafts, and some hardware were all replaced. The original 2 piece rotors were being cut as I was leaving (the one completed looked great) and new wheel bearings (inner and outer) were being inspected. The oil pan was hot tanked and the dents removed - slug too(!) and the gasket replaced. The flywheel was about to be cut, and the new Ram clutch will be installed shortly too. Delco front shocks should be in today...
New bushings are pressed in the new rear leaf springs along with new hardware... and then some Uncle Sam Scardino Traction Action Bars will be installed, with new rear KYB shocks. The diff and trans are the last items to be gone through and then we're smooth sailing. Waiting on some new rubber and still toying with the exhaust system swap. Enough jabber now onto the photos...
Evidence of an original front bumper guard car...
Lower control arms were hot tanked too
clean internals
Moog replacement parts
tanked drag link and tie rods (both original)
peak of the offset shafts
rear drums getting cut
original upper ball joints
and lots to clean
