Old 01-31-2016, 09:02 AM
Rixls6 Rixls6 is offline
Default Re: Silver 69 Chevelle SS396 Post Sedan L78
Definitely a great day for you and Mia.
She makes the car, and we'll have to get a pic of her in the driver's seat after it's that far along.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 01-31-2016, 12:05 PM
Got a floor put in, in place of Mia.
Rick
Old 01-31-2016, 12:52 PM
Ryan1969Chevelle's Avatar
I love the way you guys make the repairs:-)
If you have any snapped off body mount bolts I would love to know how to fix this issue......
Ryan
Old 01-31-2016, 01:02 PM
Yes, had a couple body mount bolts snap, or have to be cut off.
If you look closely in the last picture above, you'll see a small square metal tab sticking up on the raised area. We had to cut that on 3 sides to get at the caged nut, then cut the cage, remove the nut with busted bolt, heat the nut cherry-hot, then removed the broken bolt. Put the nut back in the cage after cleaning the threads, and weld the cage shut again.
Other methods may work depending on if the nut spins in the cage or not.
Rick
Old 01-31-2016, 01:24 PM
chevyman0429's Avatar
I see original GM metal going back in that's great!
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 01-31-2016, 01:27 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: chevyman0429</div><div class="ubbcode-body">I see original GM metal going back in that's great! </div></div>
There is no other option [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 01-31-2016, 02:06 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: chevyman0429</div><div class="ubbcode-body">I see original GM metal going back in that's great! </div></div>
Dan </div></div>
Your absolutely right that's why my black 69 is not finished yet I'm not putting anything else on it. Just picked up the last piece like a week ago. The front bumper filler/valance! My wife was actually pissed because she wants it done so I can move on to my other 69 but I told no Jap metal.
1983 chevy shortbed
1985 chevy shortbed
Old 01-31-2016, 02:11 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body">Yes, had a couple body mount bolts snap, or have to be cut off.
Other methods may work depending on if the nut spins in the cage or not. </div></div>
I have heard about it but not seen it till now..
Can you grab a few action shots?
I am nervous to cut into my nice floor to do this so I want to make sure I am heading down the right road:-)
I have 2 or three at the back especially:-( I guess I cut into the trunk to fix them:-(
I have one where the area is rusty so I am able to fix it from the bottom...... (About a 3 inch rusty area around one mount so I need to fix it.
Sorry to reply all about me on your thread, but I see this stuff and absolutely have to know for myself:-)
Ryan
Old 01-31-2016, 05:57 PM
You might try drilling a small hole in the floor above the rusted nuts, and squirting some PB Blaster in a few days before you try loosening. If there is enough bolt left, weld a nut onto it instead of using vise grips.
Rick
Old 01-31-2016, 06:15 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body">You might try drilling a small hole in the floor above the rusted nuts, and squirting some PB Blaster in a few days before you try loosening. If there is enough bolt left, weld a nut onto it instead of using vise grips. </div></div>
That sounds like a great first step!!!
Ryan
