Old 08-21-2018, 07:46 PM
L16pilot L16pilot is offline
Thanks for the response James. I just sent two original sets of '70 hoses off to be re-plated, but was hoping there was a "new" source for the correct crimps. From the few individuals I've spoke with, no one really wants to do single crimps due to potential liability issues.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
Old 08-21-2018, 10:55 PM
after looking at it... it's a leaf type die with multiple wedges which squeeze together in a cone type hydraulic press drive the cone in further it crimps tighter and tighter. The shape of the die leaves which contact the collar is an elongated ellipse with the ends lopped of. EASY if someone has an old set of dies. IF SOMEONE has DIES they can be reshaped on the ends even if you have to weld them then reshape them by hand.
Old 08-22-2018, 01:24 AM
njsteve njsteve is online now
Is there overspray on the tank straps? If I recall correctly, they were installed and hanging when the car body went through the paint booth so the will have a strange overspray pattern. Here is the underside view of my untouched, white 73 SD455. You can see that the overspray comes from the sides of the car and a little from the rear
73RSLTZ (08-22-2018), tckertbran (08-31-2018)
  #134
Old 08-22-2018, 03:43 AM
probably not enough steve... but there is some there...
  #135
Old 08-22-2018, 11:58 AM
73RSLTZ's Avatar
73RSLTZ 73RSLTZ is offline
It’s getting closer to being done. I really have to thank my brother firstgen addict!!
The brother of the infamous firsthgen addict
1973 RS Type LT Z28 4spd
1973 L82 Black Corvette 4spd Original special order paint.
1997 Polo Green SS Camaro
2002 Electron Blue Z06(sold)
The Following User Says Thank You to 73RSLTZ For This Useful Post:
  #136
Old 08-24-2018, 03:21 PM
hubleyman hubleyman is offline
Really enjoying the progress on this car! Can't wait to see it all together...
Couple of minor tidbits to mention.
My 02A 73Z still has the original 854 battery cable. Yours might be one of the last of the 855's that were used, or perhaps they just installed a leftover cable that was still a correct fit?
Also, I believe the Z87 splash shield on the side of the cowl gets installed on the front side. Mine was upon disassembly. I'm sure others could chime in and verify if it should be that way...
Keep going !!
Charlie (aka: hubleyman)
The Following User Says Thank You to hubleyman For This Useful Post:
73RSLTZ (08-26-2018)
  #137
Old 08-24-2018, 04:26 PM
McCune McCune is online now
Keep going !!
Correct, the gasket seal is bolted from the front side.
The Following User Says Thank You to McCune For This Useful Post:
  #138
Old 08-24-2018, 10:49 PM
On my 70 they were in front
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
  #139
Old 08-31-2018, 01:35 AM
Some shots of the color for the wheels...
This was mixed using the old PPG Lacquer formula tint names TRANSFERRED over to same tint names in AXALTA in the same quantities.
NO FLATTENER YET and NO TEXTURE
SEM TEXTURE COAT SHOT FIRST!
The Following 2 Users Say Thank You to firstgenaddict For This Useful Post:
73RSLTZ (08-31-2018), tckertbran (08-31-2018)
  #140
Old 08-31-2018, 09:53 PM
Ricks72Z28 Ricks72Z28 is offline
Seen a few cars where the straps are the body color, based on having the Z21 option. Search the topics at Nasty Z28 as it was discussed in length a few years back.
1970 Camaro
1972 Z28,
1973 Corvette L82,4 speed
1974 Z28 LT,M20,AC,18k Original Miles
2007 Ford Shelby GT500 40th Anniversary
