Old 12-20-2018, 02:12 AM
m22mike's Avatar
m22mike m22mike is offline
We could not make much of that green mark. After thinking about laying under the car taking that photo, the green mark and orange stripe are forward.
Mike
Old 12-20-2018, 03:10 AM
Woj's Avatar
Woj Woj is offline
Good stuff Mike and Grady. Thanks for posting. This should solve the drive shaft striping for 69 BB MT (Muncie). Grady, those stripes are crisp and clear!!!
Old 12-20-2018, 03:32 AM
cheveslakr cheveslakr is online now
Yes, thanx to all. My comment was how a BY code on the buildsheet ended up with orange/blue/yellow with a green daub ahead of it?
Old 12-20-2018, 08:26 AM
Woj's Avatar
Woj Woj is offline
One of our local guys who worked at the Chevy plant in Cleveland where they did make drive shafts suggested the third stripe may have indicated what shift made the part. I wouldn't say that is cast in stone yet, but since other GM parts had similar indications, it may be right.
Old 12-20-2018, 12:58 PM
SS427's Avatar
SS427 SS427 is offline
Based on my experience with 70 Chevelles I have always interpreted the orange stripe to confirming that it was balanced. I see this color all the time on 70 shafts and the third (or sometimes 4th) stripe is most often orange. I say 4th because it was common for Kansas City shafts to repeat one of the two colors such as pink blue pink. The orange stripe is often much further away from the other stripes as well.
Rick Nelson
Old 12-20-2018, 01:11 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Phenomenal resto Rick. Thanks for all the posts. You're frame/suspension detail work is second to none IMO. A couple of those pics of the caliper/control arm areas are pure artwork.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
The Following User Says Thank You to HawkX66 For This Useful Post:
chevyman0429 (01-03-2019)
Old 12-20-2018, 03:36 PM
----As long as we are talking about striped driveshafts, please educate me. I see so many driveshaft stripes done so neatly on restored shafts. Usually taped off and near perfect. This isn't what I remember at all. Am I right thinking the stripes are basically slopped on with, most likely, a brush?...….Bill S
Old 12-20-2018, 04:21 PM
m22mike's Avatar
They were applied by hand while the shaft was still in the lathe, or balancing machine. Have talked with a couple guys that built shafts at Parma Chevrolet
Mike
Old 12-20-2018, 04:19 PM
Correct Bill.....we make the way nicer than they ever were.
Some say, it’s a sickness
Old 12-20-2018, 05:51 PM
SS427's Avatar
I have never seen any 1970 shafts that were nice and neat and always looked haphazardly applied. However, the 69's that I have seen, especially mine were nearly perfect in application with very sharp edges like they were taped. However, I know they were never taped so likely change a change in the method they used to place them.
Rick Nelson
