Old 12-07-2019, 08:24 PM
Enoch Enoch is offline
Banned
Original big block short fuel pump mounting bolts, B&H head marking and L in a circle stamped fuel pump push rod plug. Very nice restored original pieces. $40 PP FF (X3)
************SOLD************
(#25)
Old 12-07-2019, 08:30 PM
Banned
396 427 454 4 bolt main large oil plug. W stamped. This goes into the one inch hole just above the oil filter. Very nice, very hard to find. $50. Ppff (X3)
(#30)
Old 12-07-2019, 08:32 PM
Banned
302 350 Aluminum valve cover grommets. Original design
AB embossed. $30 (X3) **********SOLD**********
(#32)
Old 12-07-2019, 08:38 PM
Banned
Excellent original restored High Performance Small Block crankshaft balancer mounting bolts with safety wire hole. TR head marking. External toothed star washers have the flat ends not pointed. Very nice original pieces. $45 each. Ppff (X3) *****ALL SOLD*****
(#56)
Old 12-07-2019, 08:43 PM
Banned
Exceptionally nice three-quarter inch heater hose to water pump fitting, long style with notches on corners of each hex. As nice as you'll see. $30. This is correct for short water pump style Motors. Both small and big block. (X3) ************SOLD************
(#60)
Old 12-07-2019, 08:46 PM
Banned
Small block high performance 87° water pump bypass fitting. Excellent original restored piece. $30 (X3)
(#62)
Old 12-07-2019, 08:49 PM
Banned
Spin on oil filter adapter to block mounting bolts. Rbw head marking. Recently replated. Excellent condition. $15. Ppff. (X3)
(#68)
Old 12-07-2019, 08:52 PM
Banned
Original free standing 4 hole wire looms. $20 each (X3) **********SOLD**********
(#76)
Old 12-07-2019, 08:55 PM
Banned
Original assembly line installed white stripe vacuum/smog hose. 13-1/2" long. $35 (X3)
(#78)
Old 12-07-2019, 08:57 PM
Banned
Original assembly line installed white stripe vacuum / smog hose. 18-1/2" long. $45. (X3)
(#79)
