Old 03-07-2016, 11:33 PM
kwhizz kwhizz is offline
Default Re: 57 Nomad Project.........
Got all the radiator hoses installed and sealed........also got all the intercooler lines run and sealed up then filled both the Radiator and Intercooler........Almost time to put the Hood back on........so.....I have to make a mount for the throttle pedal and get the fuel system mod's completed and the exhaust system made.......But...other than that.....Engine compartment sure filled up....LOL
Old 03-07-2016, 11:59 PM
Awesome....video please when you are ready [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 03-09-2016, 08:30 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Looking good as always Ken, can't wait to see it this summer.
Jake Dykstra
Dykstra Motorsports
Old 03-16-2016, 08:26 PM
Any updates, Ken?
Old 03-16-2016, 09:31 PM
Well........The last big hurdle is the Fuel system......Two issues here.......#1....The Nomad gas tank is nothing like a stock 57 tank......with the spare tire well in the rear floor....there wasn't too much room left for a gas tank.....so GM pretty much form fit a tank in the space that was available......as you can see........
And a new tank I bought for Modifications.............
I'm using a GM LSA Fuel pump which is 7 1/2&quot; high and the Nomad tank is 12&quot; deep.....So......two problems....the GM pump needs to be spring loaded against the bottom of the tank......so...I need to build a recessed mounting system for the GM pump......and I need to lengthen the stock LSA pump to replicate the stock compressed GM specs......Here are some pic's of the Tank Modifications.......Should be finished later this week........
More to come
Old 03-16-2016, 09:48 PM
Also..........To get the old Nomad tank out of the car I basically had to just about take the rear axle assy out........I disassembled everything and slid the housing forward on the springs to get enough room for the tank to come out.......And....as long as I am ripping the rear of the car apart, I had an Axle oil seal leak on the passenger side, so....pulled the axle out to get that fixed.......then I checked and found out the rear was an open rear......so....pull it all apart and took the third member to get a Posi unit installed.........used a couple cans of Brake clean to get the oil out of the parking brake assy and to get the pads and rotors cleaned up......should have the rear ready for reassembly when the tank is finished.....
Old 03-16-2016, 10:13 PM
And........The Fuel pump.........A couple of concerns here.......The GM pump has exposed wires that are submersed in the gasoline........So....I found out by asking the experts on LS1tech how to extend the wires while lengthening the pump......I was told to use PTFE wire and shrink tubing only.......took a while to locate the Teflon insulated wire and shrink tubing......finally got everything and got the wires fixed.........next was the flexible &quot;Soda Straw&quot; feed line from the pump to the outlet port on top of the assy........couldn't figure out a good way to lengthen the corrugated plastic tube without crushing or restricting the line........so.....I ended up getting some -8 braided stainless fuel hose and it worked out perfectly......I cut off the plastic tube and left the stock GM RF sealed tube ends on the fittings.....the -8 hose fit over these tube ends perfectly and will be held on with stainless hose clamps.....then I made some stainless rod extenders and longer springs to make the pump to the new length.........all finished, just need to wire tie the wires to neaten then up.......
Old 03-16-2016, 11:39 PM
earntaz earntaz is offline
Ken -- I hope you don't take this as being too critical ... but the aircraft locknuts (nylocks) in the brake assembly do not appear to be engaging the nylon. Bolts appear to be a skoshi too short. For safety sake -- check it out. TAZ
Old 03-16-2016, 11:42 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Ken -- I hope you don't take this as being too critical ... but the aircraft locknuts (nylocks) in the brake assembly do not appear to be engaging the nylon. Bolts appear to be a skoshi too short. For safety sake -- check it out. TAZ </div></div>
Everything was disassembled to get the axles out and the nuts were just screwed on with a couple threads (Just so I wouldn't lose them till reassembly)........Good Eye ......LOL
Ken
Old 03-17-2016, 01:14 PM
Getting closer!!
