Old 08-31-2020, 11:24 PM
Discover The Science Behind Car Camouflage
https://www.msn.com/en-us/autos/enth...?ocid=msedgntp
Old 08-31-2020, 11:39 PM
The rear is a shortened Impala.
Originally Posted by big gear head View Post
The Chevelle has a different rear suspension from the Impala, so it would have been a Chevelle rear end with Impala tubes, or the frame would have been modified for the Impala suspension. I would bet that it just had Impala tubes.
Z16 rear is not just a shortened Impala rear. It really is a "Z16-only" rear. Center section and all suspension parts are Chevelle. The tubes and bearing ends are shortened Impala tubes. And as I mentioned the axles are one-offs. The rears for the two "prototype" cars were built first, then once fitment was confirmed all 200 production rears plus ?? service units were built in a single run over two days in December of 1964.
spindle, backing plate and drum are Z-16 only.
I wonder why this was. Impala standard wheels were 14 x 5 with wagons getting 14 x 6. You could order the 6" wheels under RPO P12 with mandated 8.25x14 tires.
Because the Impala had a 5 on 5 bolt pattern?
Stud spacing is the same on Chevelles and Impalas. But the offset of the 14x6 wheels on those two models is not.
The Z16 wheels and front brake drums appear to have been the result of "trial and error" fitment on the prototype cars.
14x6 wheels with the Chevelle offset will not fit over Impala rear brake drums. They wedge onto the back edge of the drum before the center of the wheel mates the face of the drum, so the lugs cannot be tightened all the way. They fixed that by having the special Z16 14x6 wheels made to fit over those big rear drums.
Only problem with that was then the rivets that hold Z16 wheels together prevent those from fitting over Impala front drums! So the front drums had to be altered to accept the Z16 riveted wheels.
There are lots of other one-off parts on Z16's. So they clearly were not worried about costs or making a profit in that program! But it really is a shame that they did not offer an HD suspension option in 66-67 using the boxed frame with Z16 brakes, rear sway bar, and giant front sway bar. The parts were designed and they could have kept making them and recouped some of those costs.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following 3 Users Say Thank You to jeffschevelle For This Useful Post:
67since67 (09-01-2020), big gear head (09-01-2020), Lee Stewart (08-31-2020)
  #16483
Old 09-01-2020, 12:30 AM
x77-69z28's Avatar
Originally Posted by Keith Seymore View Post
You are correct, but props to the kid for not lifting!
K
Absolutely!
Old 09-01-2020, 02:03 AM
Old 09-01-2020, 02:04 AM
olredalert (09-01-2020)
  #16487
Old 09-01-2020, 02:06 AM
Canada, 1959. A Mercury Big Job 800 and a Mack B-61 working in tandem hauling 80 foot logs to use as stringers for a bridge project. The Mack went forward while the Merc went backwards! They drove this way for 28 miles to the bridge site.
Carleen (09-08-2020), downunder1 (09-03-2020), olredalert (09-01-2020)
  #16488
Old 09-01-2020, 02:24 AM
If you are a fan of the Robert B. Parker Spenser series, Ace Atkins is continuing the stories. I have read them all and they are just as good as the originals. You can probably get them at your local library.
Old 09-01-2020, 02:25 AM
Getting old sucks!
PeteLeathersac (09-01-2020)
  #16490
Old 09-01-2020, 05:35 AM
