Old 06-27-2016, 11:21 PM
Ryan1969Chevelle's Avatar
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Glade Green vs. North Carolina Blue this will be a nice photo at the starting line. I see Ryan, improving his times upon every run....and almost catching Chris. It will be a fun day [img]<<GRAEMLIN_URL>>/[/img]
Dan </div></div>
I can picture it now:-)
Ryan
Old 06-27-2016, 11:28 PM
junior supercar junior supercar is offline
pic from 2009, when I was doing a little TnT. that's the original paint or whats left of it
car is code 80, powder blue. paint chip chart shows it's a toro exclusive color. blue interior, buckets, console, am radio, rallye pac, TH350, 3:91 anti-spin. SSI originally, but I'm going to run SSII (I just like them better)
no clue when the car will be ready. I'd guess end of 2017 at the earliest.
distr dates codes are number for year, followed by letter for month, followed by numbers for day of the month. Usually they are to the right of the casting nbr. for example, 1C30 would be 1971, March 30.
1969 Cutlass S W-31 - 13.86@100 TnT US41 2009
1970 Tempest GT-37 400ci 4bbl 4sp - [email protected] PSMCDR 2011
1970 F-85 - daily driver or clock it with a sun dial
plus others
Old 06-27-2016, 11:29 PM
Thanks Chris,
Looks like she was strong before coming apart!!
How about the plug wire codes?
Ryan
Old 06-27-2016, 11:30 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">A Carolina Blue '69 W-31 may very well be a 1 of 1....as I have never seen another [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Dan </div></div>
it may be. I've only seen pics of one other 69 Olds A-body in this color. Car was missing drivetrain, but it may have been a W-31 also.
plus others
Old 06-27-2016, 11:37 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Thanks Chris,
Ryan </div></div>
I had the original drivetrain rebuilt. 10.6:1 compression, built to PSMCDR specs. it's running the SSII with F70x14 GY PG. Oh and 4:33 gears :-) I learned a TON when the 400 for the GT-37 was built, so I'm planning to put that knowledge to use when a new motor for the 31 is built. New trans has already been done :-)
Plug wires - they are by quarter. 1 Q 69 is first quarter 69. 4 Q 68, would be 4th quarter 68. I think mine on the 31 are 2 Q 69 (going by foggy memory). Car was built 05C
plus others
Old 06-27-2016, 11:39 PM
That makes sense my car is 03B built first quarter of 69:-)
Ryan
Old 06-27-2016, 11:41 PM
Nice Chris.....I like the Fuzzy Dice :-)
Old 06-28-2016, 12:42 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Nice Chris.....I like the Fuzzy Dice :-)
Dan </div></div>
ha. nice. I was going to point that out, but you picked it up
plus others
Old 06-28-2016, 02:03 PM
83hurstguy 83hurstguy is offline
I'd ditch the heat riser, just make sure the choke works on the carb, you'll be fine. I started and ran my '83 without issue a ton of times with headers (so no heat riser) and a working choke in single digit temps. You get heat from the exhaust crossover under the carb anyways. The stock manifolds are already restrictive enough...
'68 H/O W45
'70 Cuda
Old 06-28-2016, 03:01 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 83hurstguy</div><div class="ubbcode-body">I'd ditch the heat riser, just make sure the choke works on the carb, you'll be fine. I started and ran my '83 without issue a ton of times with headers (so no heat riser) and a working choke in single digit temps. You get heat from the exhaust crossover under the carb anyways. The stock manifolds are already restrictive enough...</div></div>
Good enough -- just takes a skoshi longer for the manifold to heat up. Another issue is when using stock exhaust head pipes, because the heat riser (about 2&quot; thick) was removed, now the pipe may be too close to the floor pan ... assembly will show what the clearance is ... TAZ
