Old 07-15-2023, 12:59 AM
OneStopRestoration OneStopRestoration is offline
Default Rims and Tires
Ive decided to depart some from original on the rims and tires. The original size of rim and tires on these cars is laughable at best for a muscle car. Because of that I went with some new 14x6 rims, and redlines from the 67 model year. Im going with body colored rims and dog dishes.
The Following 5 Users Say Thank You to OneStopRestoration For This Useful Post:
67 Nova Boy (07-22-2023), 69M22Z (07-15-2023), big gear head (07-15-2023), dykstra (07-19-2023), olredalert (07-15-2023)
Old 07-15-2023, 01:02 AM
Default Front End
After a very long drawn out process to get the bumper chromed, the place i worked with actually destroyed the original from the car. I spent several phone calls back and forth to discover they took my perfectly formed bumper and reformed the angle it makes to match the front end because they claimed to have a form, and my bumper didnt fit it. In the end i sent them another core and told them to stop putting in there form. What ended up with was a nicer bumper that perfectly fits the lower splash pan under the grille. The car is really coming together now.
The Following 17 Users Say Thank You to OneStopRestoration For This Useful Post:
169indy (07-19-2023), 1967Z28 (07-15-2023), 67 Nova Boy (07-22-2023), 67since67 (11-11-2023), 69M22Z (07-15-2023), big gear head (07-15-2023), cheveslakr (07-15-2023), Dave Rifkin (07-15-2023), dykstra (07-19-2023), HawkX66 (07-18-2023), L78_Nova (07-17-2023), L_e_e (07-15-2023), napa68 (07-15-2023), olredalert (07-15-2023), Tenney (07-15-2023), Too Many Projects (07-15-2023), Xplantdad (07-15-2023)
Old 07-15-2023, 01:39 AM
Wow, beautiful.
If you aren't going to save the reject grille for future use, I might be interested in it. I, also need some trunk paint, if you are still making that. I'll send you a PM. I could swing by your place to pick it up on my way back from SCR on the 22nd.
Old 07-18-2023, 12:46 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
Hi Rick,
This thread of your beautiful ‘66 396 Chevelle restoration is awesome, not to mention it’s being done in my old stomping grounds of central Illinois.
I was born in ‘54 in Springfield and traveled to just about every town including Washington/Peoria area in my good old days. Many corn fields.
The time, money and sourcing parts that’s required for a high end restoration like yours is exhausting. Congratulations to you for this undertaking.
This old muscle car was very fortunate to have found you!
Factory vinyl (Cordova) top.
I’m a GTO (65-67) guy and the Cordova tops on these cars always received a flexible retainer. I’m not sure if the Chevrolet models used this item?
Shown below is this retainer on my ‘65 GTO Survivor.
This retainer was also used on the 66-67 Tempest Series cars with this fabric top, but in a different translucent material opposed to the chrome retainer on my 65.
Looks like you’re on the downhill of this project and it looks fantastic!!!.
Thanks for sharing this restoration.
Chris.
The Following 9 Users Say Thank You to 60sStuff For This Useful Post:
67 Nova Boy (07-22-2023), 69M22Z (07-19-2023), big gear head (07-18-2023), dykstra (07-19-2023), HawkX66 (07-20-2023), olredalert (07-18-2023), OneStopRestoration (07-19-2023), Tenney (07-19-2023), Xplantdad (07-18-2023)
Old 07-19-2023, 12:16 AM
Hi Chris,
Really appreciate the comments. I have noticed that for those that really get into the hobby, passion and obsession become a blurred line.
So my car did have those inserts when i was in the disassembly process. I have heard/read that some others have had success in removing them for reuse. I was not one of those people so i just glued the top down and installed the drip rail moldings.
Where did you get the page from? That something produced by Body By Fisher?
The Following User Says Thank You to OneStopRestoration For This Useful Post:
Zman1969 (08-15-2023)
Old 11-11-2023, 09:13 PM
Default Engine Finally Back In and Running
After the flat tappet fiasco, thankyou Comp Cams. I yanked the engine put an erson roller and started the engine on a run Stand. I have determine engine run in stands are the only way to go from now on. All worked out great. The erson cam is most to the stock specs with just .010 more lift on both intake and exhaust. Opening and Closing valve events plus duration are pretty close and it sounds Excellent! As soon as the hood is on and i square away an alignment i will post final pictures for this project.
Engine running in the car
https://youtu.be/4_kYUOM9U1Y?si=bCC3UKCk0J3PiQTM
The Following 9 Users Say Thank You to OneStopRestoration For This Useful Post:
carnut4life (11-11-2023), cheveslakr (11-12-2023), dykstra (11-12-2023), napa68 (11-11-2023), olredalert (11-12-2023), PeteLeathersac (11-11-2023), RPOLS3 (11-12-2023), Tenney (11-12-2023), Xplantdad (11-12-2023)
Old 11-11-2023, 10:54 PM
scuncio scuncio is online now
Can you share the source for your engine run stand?
Old 11-11-2023, 11:25 PM
Car looks great!
Those vinyl top drip gutter retainer strips were stainless steel in 63 - 66. Then in 67, depending on the assembly plant and the time frame, they were either black plastic, or clear plastic with an embedded mylar chrome strip.
The stainless strips are indeed very hard to remove without destroying them. I've been successful a few times, but you need to plan on about 2 hours per side to get it done!!
The mylar 67 version shows up on eBay fairly frequently. It is not "correct" for a 65 or 66, but lots of people use them as a substitute for the original stainless strips.
Here's a set on eBay now: https://www.ebay.com/itm/19572653927...Bk9SR7jOyI74Yg
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following 3 Users Say Thank You to jeffschevelle For This Useful Post:
67since67 (11-12-2023), olredalert (11-12-2023), OneStopRestoration (11-12-2023)
Old 11-12-2023, 12:30 PM
dykstra's Avatar
dykstra dykstra is offline
Sounds great Rick!!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
Old 11-12-2023, 01:11 PM
It sure does!!
