Old 09-25-2016, 02:48 AM
Ryan1969Chevelle's Avatar
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
I used what grinder and wire wheel I had around to get started tonight.
The layer of crusty rusty stuff cleaned off fairly easily and the metal underneath looks perfect at the sample spot.
Ryan
Old 09-25-2016, 02:57 AM
Rixls6 Rixls6 is offline
Metal looks pretty good after the clean up.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 09-25-2016, 03:06 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body">Metal looks pretty good after the clean up. </div></div>
So far so good:-)
I flipped over the condition of the floor pans:-)
Ryan
Old 09-25-2016, 12:23 PM
I gave you a back flip and a score of 9.5
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-25-2016, 12:38 PM
You know what I am going to say.....now is the time to get the firewall and cowl done too....it just makes sense. Take your time and do it right!
Do it [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] You will be happy you did.
Old 09-25-2016, 01:03 PM
i plan to restore the firewall as well as the floor, but I am starting at the back so the harder part is completed first.
I plan to sneak out for another hour of grinding today:-)
As we talked a while ago, this is awkward work so many shorter visits will be much more efficient.
When I get to the firewall I probably need to remove a few items, the master needs to be real webbed/rebuilt so I have that planned. The other items like windshield washer motor may need to be removed to access behind it. (It will be cleaned only for now and restored as a winter project in future) I need to be careful not to do too many MAW diversions.
Ryan
Old 09-25-2016, 01:23 PM
Indeed, remove everything off the firewall.....including heater box, replace the heater core.....nothing worse than having a car finished to find a leaky and faulty heater core.
Old 09-25-2016, 02:41 PM
Yes I have a budget/cost item in my spread sheet for a NAPA heater core. I have the hoses, and clamps ready.
Is there a gasket on the heater box?
By memory the heater box should be a different gloss than the underside/firewall?
Ryan
Old 09-25-2016, 03:03 PM
Jonesy's Avatar
Jonesy Jonesy is offline
You should check into getting your original heater core rebuilt instead of buying a NAPA replacement. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-25-2016, 04:16 PM
I didn't know heater cores are rebuilt:-)
I will ask the shop that will be doing my rad:-)
Ryan
