Old 10-13-2008, 05:03 AM
Chevy454 Chevy454 is offline
Default Re: AC Delco R43 Spark Plugs
Problem is, Delco doesn't make their plugs any more...simply repackages them...wanna say they're made by the same place that makes Champion plugs? The side cut Autolites work ok. When we messed with plugs on the dyno, my beloved AC's were horrible...no matter of the heat range, they all SUCKED...stuck in an NGK, and I've never looked back...
Here's some plug info I posted a while back:
<u>Z28 &amp; LT-1 with 186 heads:</u> my AC book calls for a C43 or an R43 plug, and the NGK site says-
Standard, V-power (3/8" reach, 13/16" hex, projected tip, gasketed seat):
XR4 / 5858
XR5 / 3332
Race, V-power (3/8" reach, 5/8" hex, projected tip, gasketed seat):
R5670-6 / 4449
R5670-7 / 5034
R5670-8 / 5657
R5670-9 / 6468
R5670-10 / 6702
<u>L78 &amp; L72 with 840 heads:</u> my AC book calls for a R44 or a 44N plug, and the NGK site says-
Standard, V-power (3/4" reach, 13/16" hex, projected tip, gasketed seat):
GR4 / 2635
GR5 / 2851
FR4 / 5155 (same as GR plugs, except for 5/8" hex)
FR5 / 7373 (same as GR plugs, except for 5/8" hex)
Race, V-power (3/4" reach, 5/8" hex, projected tip, gasketed seat):
R5672A-8 / 7173
R5672A-9 / 7405
R5672A-10 / 7942
R5671A-7 / 4091 (same as 5672, but with non-projected tip)
R5671A-8 / 4554 (same as 5672, but with non-projected tip)
R5671A-9 / 5238 (same as 5672, but with non-projected tip)
R5671A-10 / 5820 (same as 5672, but with non-projected tip)
R5671A-11 / 6596 (same as 5672, but with non-projected tip)
<u>L78 &amp; LS6 with 291 heads:</u> my AC book calls for a R43T, and the NGK site says-
Standard, V-power (.460" reach, 5/8" hex, projected tip, tapered seat):
UR4 / 6630
UR5 / 2771
UR6 / 7773
YR5 / 7052 (same as UR plug except w/ non-projected tip)
Race, V-power (.460" reach, 5/8" hex, projected tip, tapered seat):
R5674-6 / 4449
R5674-7 / 5034
R5674-8 / 5657
R5674-9 / 6468
R5674-10 / 6702
R5673-6 / 2405 (same as 5674, except w/ non-projected tip)
R5673-7 / 2817 (same as 5674, except w/ non-projected tip)
R5673-8 / 3249 (same as 5674, except w/ non-projected tip)
R5673-9 / 3442 (same as 5674, except w/ non-projected tip)
R5673-10 / 4050 (same as 5674, except w/ non-projected tip)
Old 10-13-2008, 05:09 AM
47Hammer's Avatar
47Hammer 47Hammer is offline
I appreciate the information on the plugs, I wasn't 100% sure they what they were for. I'm not going to use them myself because I'm happy with the Autolites. I may just list them on Ebay but if anyone can use them, pm me.
Old 10-13-2008, 05:21 PM
I use the NGK's also. Always used the older R44S Delco's but Rob (these young guys) made me switch. The R43's will probably do pretty good on Ebay.
