Old 03-10-2009, 01:04 AM
Default Re: carburetor jets
Eric,
Was told by someone who has been into racing a long time to even out the power valves on the 302 to 65 front and 65 in the rear.I have had no problems at all with this setup,what is your opinion on this?? Mark
Old 03-10-2009, 01:22 AM
VintageMusclecar's Avatar
Mark;
I've always stuck with 6.5/8.5 with complete success, so I couldn't really say.
Eric
Old 03-10-2009, 01:52 AM
Eric, I ran the stock factory spec. 4346 carb except for the jetting. If memory serves me correctly, the PVs were both 6.5 but don't quote me on that. I don't know what the vacuum idle was. I couldn't have asked for the carb to work any better. I have a 4346 done the same way on our L78 engine and it works the same way. Having carbs that were already built for the application probably helped a lot as far as tuning went. A friend of mine does some racing and he gets into modifying the restrictors in the body of the carb, stuff that I know nothing about. When he is done, it is surprising at how well a carb can run, and how far off most carbs are when he first starts on them.
Old 03-10-2009, 03:42 AM
I just checked my old GM parts books. For '69 they list the 3877167 power valve for the rear in all applications with various PVs for the front. For 1970 they list the same 3877167 PV front and rear for all applications. Not that I trust everything in the parts books, but that is what they show.
Old 03-11-2009, 03:42 PM
SSRSBOB SSRSBOB is offline
For ultimate performance stagger jetting is the way to go. Old racing trick for stock runner intakes.
Bob
Old 03-11-2009, 08:47 PM
Chevy454 Chevy454 is offline
Rob;
I would be interested to know what your L72 idle vacuum is, and what PV you're running up front (blocked rear, correct?).
Running a 65 up front with a plug in the rear...my notebook says my usual setup for Stanton is:
<font class="small">Code:</font><hr /><pre> Front
71 | 70
85 | 82
</pre><hr />
I bumped it up +2 for the thicker in Virginia last fall, but the crazy high humidity killed it...as for vacuum, for some reason I can't find where I'd written it down, but I'm 99% positive it was over 12 @ idle...the only reason I remember it is, it was nearly identical to Stefina's R-code 427 [both in engine specs and vacuum readings].
Old 03-11-2009, 10:14 PM
Vac. sounds right considering your engine's stats.
I'm surprised it wants a 3 jet spread in the back--I'm assuming the 163 still has the plenum divider, correct?
Have you tried Maxjets?
Maxjets
I've yet to try these myself, but reliable resources say they're considerably tighter in flow tolerance than standard jets.
Old 03-11-2009, 11:08 PM
Haven't tried the new jets yet...I was always worried about having to start over on my settings, as the LM1 said I was dead nuts on last time I hooked it up...but, I *totally* understand the concept, and feel I've ran into that problem before.
Old 03-12-2009, 12:28 AM
Is your current jetting based on dyno tuning or track results?
Old 03-12-2009, 05:09 AM
Track results, naturally! Other than the standard plug checking [and now LM-1 when I remember to take it!], I basically watch my MPH, and check the DA every once in a while and make a note...
