#11
Re: Hoist/Lift Selection
Get a 4 post with the sliding jack. You can change tires etc easily. When these things came out it really advanced 4 posts [/ QUOTE ] Charley,is that jack hydralic or a hand jack? |
#12
It is hydraulic that you hand pump. Basically it is a porta power pump hooked to a scissor jack. They also sell ones that are air over hydraulic that you hook a air hose to that uses a butterfly valve. They work great. The lifting arms slide in and out for width and they have extensions that space the pads up.
I own an automotive repair shop and the best lift I have found to work on cars is a Rotary 2-post 9000# lift. the 4-post lifts require a lot more room. the two posts require a small foot print and make it alot easier to work under the car. The only reason I have a drive on is to do alignments. The rotary lifts are easy to install and cost around 3500 to 4000. just my opinion. ed
1970 Camaro L-78 1970 Chevelle L78 2015 Z-06, 2008 Z-06 |
#14
It is hydraulic that you hand pump. Basically it is a porta power pump hooked to a scissor jack. They also sell ones that are air over hydraulic that you hook a air hose to that uses a butterfly valve. They work great. The lifting arms slide in and out for width and they have extensions that space the pads up. [/ QUOTE ] I purchased the backyard buddy with the jack that hooks to the hydralics of the lift and it was 1700 bucks! I would have purchased the hand pump one if they had it. I do not know if they sell the handpump one anymore |
#15
That is a good deal
#17
I gotta agree with Ed. Iv'e been a wrench for almost 30 years and worked on a lot of lifts. I work on a Rotary 9000# now and it's great. Rotarys are more money, but are definatly worth it. Very easy to set up.
#18
If you should go with the Rotary lift, I strongly recommend an assymetrical unit.
L.Z. "...at this point in my life, every day is a Saturday". |
#19
I had this discussion on another site. For a two post you need to be sure your slab is probably at least 6" thick. For the average home use i still like the 4 post. harder to make mistakes with a 4 post.
..is that a dare.
