Old 03-31-2010, 05:47 AM
Ngtflyr Ngtflyr is offline
Default 69 Z Fuel Pump
Looking for the correct AC Fuel Pump for a 69z, found an NOS one in the original box locally, with 46987 on the box and AC on both sides of the fuel pump. The fuel pump also has 296U40867 stamped on the edge where it mounts to the block. Can anyone confirm this is the right application? Paid $60 for it so figure it's a good deal if it's the right one.
Dave
Old 03-31-2010, 06:12 AM
Steve Shauger's Avatar
Administrator
Default Re: 69 Z Fuel Pump
The part# is 40669.
www.yenko.net
www.vintagecertification.com
Old 03-31-2010, 06:18 AM
Jeff Dotterer probably has one. I bot one for my Nova from him.
[email protected]
Old 03-31-2010, 08:04 AM
That #46987 stamped pump originally was installed on:
1971 Chevelle w/AC & 350cid. w/4bbl.
1971 Monte Carlos w/small block 400cid.
1971 Impala w/AC & 350cid.w/4bbl.& small block 400cid.w/4bbl.
Depending on assembly date,I think some 69 Z's came with #40725 stamp also,showing 6470422 on the box.
Old 04-01-2010, 06:35 AM
My 69 (Z) had a 40726 pump.Still have it,but had to change it out and ended up using a 40987 showing 6470779 which doesn't have the AC on the pump.At some point in time GM stop putting the AC the there fuel pumps.
Old 04-01-2010, 07:52 AM
John Brown's Avatar
If I recall correctly, a company named Blackstone was actually making most of the fuel pumps for AC. Blackstone also sold pumps under their own name without the AC logo, but the rest of the pump was absolutely identical.
John Brown
Old 04-01-2010, 08:09 AM
Typo guys..#40726 w/box #6470423 is what my earlier reply should read..
Old 04-01-2010, 08:29 AM
Thanks for the input everybody, got the right one today and got it installed. Lesson learned for next time. It is a royal PITA replacing a fuel pump in a 69 camaro with smog, I need a long time before going there again.
Dave
