Old 12-02-2011, 02:43 AM
PxTx's Avatar
PxTx PxTx is offline
Default Re: Plexiglass scoop
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: brent396</div><div class="ubbcode-body">Very cool scoop someone should redo some plexiglass scoops </div></div>
I'm looking into this, but a mold needs to be made. What would you guys think, a clear Grump Lump may be the best design? Probably only gonna make 1 run and be done. Not really looking to saturate the market and water down the &quot;cool factor&quot;.
Most likely gonna just do clear, then you can Candy paint them to add color.
Paul III
Old 12-02-2011, 03:23 AM
x  Baldwin  Motion's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body">...... was planning on just making one like Howie did for his Camaro...... </div></div>
Old 12-02-2011, 03:38 AM
whitetop whitetop is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: brent396</div><div class="ubbcode-body">Very cool scoop someone should redo some plexiglass scoops </div></div>
Most likely gonna just do clear, then you can Candy paint them to add color. </div></div>
Paul, smoke plexiglass also look nice.
What kind of prices have you received? Did you see what I was quoted above? Of course the two co's that I approached were very large co's that deal with large corporate orders and they did not really want to mess with my small job and many co's do not have the set up to do 1/4&quot; thick plexi
The 1/4 after forming gets kinds thin...I'm not sure I would do anything less than that-engine heat might distort anything thinner????
Old 12-02-2011, 03:55 AM
PxTx's Avatar
Dave, thanks for your post about your attempt to have some made. After reading that, I knew I had to find a small fellow with low overhead.
I'm discussing it right now with an enthusiastic guy. I'm actually discussing the mold right now, that- I'll own. The cost of the scoops has not been nailed down, but I expect it to be competitive with other scoops if done in clear.
I know the colored stuff gets expensive, and I would expect smoke too. Do you see any down side to simply painting a clear scoop with candy paint?
Paul III
Old 12-02-2011, 04:46 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body"> Do you see any down side to simply painting a clear scoop with candy paint? </div></div>
I have seen some flat plexi side windows sprayed and while it looks nice from a distance you can tell up close.
I think it would be near impossible to spray candy color inside the scoop and get even coverage/no runs etc in the corners and walls.
Old 12-02-2011, 04:40 PM
YENKO DEUCE REGISTRY's Avatar
If you make some, I'm buying one for sure. I'd prefer clear, but the I'm not picky when it comes to 'cool'!
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 12-02-2011, 05:06 PM
ORIGLS6 ORIGLS6 is offline
I know a couple of local guys would be in for those as well, ........ and who am I kidding? I'd buy one for 'wall art'!!! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 12-02-2011, 07:59 PM
daverd daverd is offline
I wiil buy a scoop in any color or clear.....
2017 impala (wife’s car)
Old 12-02-2011, 09:15 PM
Paul, I would be all over one of these. This is the cool factor, what a great way to show off a tunnel ram.
Old 12-02-2011, 09:19 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Day2 speedshop</div><div class="ubbcode-body">Paul, I would be all over one of these. This is the cool factor, what a great way to show off a tunnel ram.
</div></div>
X2 - exactly why we want one too!
Marlin
