Old 09-26-2012, 02:02 PM
CanCOPO CanCOPO is offline
Default Re: E code 440 HP complete value
Quick question. My 69 Super Bee (drum brakes) is missing a rear wheel stud (Discount Tire not realizing it is LH thread). Will I have to pull the axel to replace it?
Thanks
1969 Hugger Orange RS COPO (Sold)
1969 Garnet Red Z28
1969 Super Bee (Sold)
1965 Pontiac Lemans
Old 09-26-2012, 02:10 PM
69hemibeep 69hemibeep is offline
No just pull the drum and drive it out,sometimes you can get the new stud to seat useing an oversize nut as a spacer and a lug nut to pull the stud in, make sure the threads are greased and don't overdue it, it may need pressed to seat it . Do you have another LH stud?
Can't get enough muscle
Old 09-26-2012, 04:08 PM
Thanks and much appreciate. I have a left hand stud. My mistake letting someone else mess with it and not overseeing.
1969 Garnet Red Z28
1965 Pontiac Lemans
Old 09-27-2012, 03:45 PM
If Discount Tire broke it, why didn't Discount Tire fix it?
Jason
Old 09-27-2012, 08:04 PM
A ggod question. Lots of guff about not doing anything mechanical.
1969 Garnet Red Z28
1965 Pontiac Lemans
Old 09-28-2012, 12:30 AM
They should at least pay or compensate some how. I went to a mom and pop tire store for new skins on my truck and when I returned for rotation they found they had cross threaded a nut when installing the new tires. With out saying a thing he gave me a new chrome nut and told me to bring any billing in to replace the stud. Thats why I go there.
Old 09-28-2012, 01:21 AM
"If Discount Tire broke it, why didn't Discount Tire fix it?"
Because they probably do not know how to fix it, why do you think they call it Discount Tire? I own a "Mom & Pop Shop" and have for the last 27 years. We have repaired may of Discount Tire's mistakes along with NTB's.
Like I told a customer once when she went back to Discount Tire 3 times to get her car not to pull to the right after 4 new tires and a "Free" alignment....what kind of job did you expect to get out of a tech working Sunday afternoon? Her response was "But you were $44.25 more. She ended up paying us $125.00 to road force balance her 4 tires (we found 1 to be defective and she had to go back a 4th time to warranty it) and perform a 4-wheel alignment Which was out of specs. Like everything else in life, you get what you pay for.
Bill
Old 10-01-2012, 04:23 PM
Another quick question for you. Neither of my doors on the 69 Beewill lock. Tried all combinations (holding in on door button, etc.). They won't lock with the key either. I thought it was strange that both sides behave the same and I am trying to avoid pulling the door panels.
1969 Garnet Red Z28
1965 Pontiac Lemans
Old 10-02-2012, 01:48 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: CanCOPO</div><div class="ubbcode-body">Another quick question for you. Neither of my doors on the 69 Beewill lock. Tried all combinations (holding in on door button, etc.). They won't lock with the key either. I thought it was strange that both sides behave the same and I am trying to avoid pulling the door panels. </div></div> the door button works when the door is closed I hope. The door uses the ignition key and they are designed so you cant lock yourself out. The button only works with the door closed it will reopen if you lock it and shut the door. Sounds to me as if you need to re-key the doors I think your ignition switch was switched.
Old 10-05-2012, 10:26 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69hemibeep</div><div class="ubbcode-body">I'm about to pick up another 440, intake to pan if the guy will return my call. Nothing like what you have but it is an E block with a cast crank(Oh well that will have to go)and I'm not sure which heads yet $350. Have you tried to market yours yet? </div></div> I ended up getting it for $250 and I have a line on another with the 727 behind it. Granted they are not as desirable as what you have and its the region, prices are better for buyers and friends from Florida and California are amazed, they would pay triple.
