Old 12-16-2013, 05:12 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default Re: decoding bbc
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RichSchmidt</div><div class="ubbcode-body">Go buy a powerball ticket,you just found one of the most valuable big blocks ever made. It can be converted to 4 bolt caps and have the pipe plug on the side machined out,all for under $500 or so,and unless it is cracked it is probably worth about $4-5K. Pretty much it is a date code and casting correct block for somebody's Yenko/COPO car. </div></div>
hold yer horses hombre. The suffix code &amp; partial VIN will always peg this as an Impala block so... $4-5K? Not a chance. Save your $500 OP
I ain't nobody, dork.
Old 12-17-2013, 04:34 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RichSchmidt</div><div class="ubbcode-body">Go buy a powerball ticket,you just found one of the most valuable big blocks ever made. It can be converted to 4 bolt caps and have the pipe plug on the side machined out,all for under $500 or so,and unless it is cracked it is probably worth about $4-5K. Pretty much it is a date code and casting correct block for somebody's Yenko/COPO car. </div></div>
hold yer horses hombre. The suffix code &amp; partial VIN will always peg this as an Impala block so... $4-5K? Not a chance. Save your $500 OP </div></div>
Yes and decked or REBROACHED blocks which have been restamped are quite easily discernible. It will always be a low HP 512 block whether it is doctored to look like something else or not!
Survivors, restored cars, &amp; other photos
