Old 05-11-2015, 03:49 PM
earntaz earntaz is offline
Default Re: 4-speed Muncie trans
Jason -- X2 ... Geez, where's my piece of broom handle for the installing the cluster? LOL
Old 05-12-2015, 06:45 PM
COPO_Anders COPO_Anders is offline
Yes Verne, that´s a good method ! I´m guessing it´s a wide ratio, but we´ll try that and see what we find. I´ll get back with the result. Thank´s all !
[img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
Anders Stålklint.
After selling my COPO 9561 I´m now a "postman" with the main project being a 1966 327 2 dr sedan Chevy II.
Old 05-12-2015, 07:19 PM
WILMASBOYL78's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: scuncio</div><div class="ubbcode-body">Muncie from a 1968 Nova. I don't believe you can tell M20/21/22 in '68 unless you pull the trans and count the grooves on the input shaft (2=M20, 1=M21, 0=M22) </div></div>
M22 will have the drain plug...build date makes it a possible BB application. They didn't start using the A,B,C codes until fall of 68 [69 models]..Nova Muncie 4 speeds are rare...might have some value to a Nova guy looking for a dated part.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 05-12-2015, 08:11 PM
Pull the trans and fix it COPO.
Better yet, put a Jerico in it or a Nash 4+1.
By the time you guys figure out what trans it is you can have it out.
And we sent all our good old Pro Stock cars to Sweden. GEEZE!
(:&gt;
Old 05-12-2015, 10:27 PM
SS427's Avatar
SS427 SS427 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: WILMASBOYL78</div><div class="ubbcode-body"> Nova Muncie 4 speeds are rare...might have some value to a Nova guy looking for a dated part.
wilma </div></div>
Like this one......came to me in an LS6. Needless to say I replaced it with the correct part and bought this one for my inventory.
I should add, don't always assume that a trans is an M22 based on the drain plug and/or stampings. You can always put M20-M21 guts in an M22 case. Also, I believe starting in 1970 all Muncie 4 speed cases were drilled for drain plugs.
Rick Nelson
Old 05-20-2015, 06:57 PM
He didn´t get back to me right away. Apparently he did make the Verne-test and found out that it was a M-20. He has pulled the trans and is going on a 150 mile trip to a guy who knows Muncie´s inside and out, as we don´t know of any Muncie guys locally. I think he said that guy is around 75 now.
[img]<<GRAEMLIN_URL>>/[/img]
Anders Stålklint.
Old 05-20-2015, 07:30 PM
I like the wide ratios very much. You can run a higher rear gear for lower rpm at highway speeds and still have an easy launch without riding the clutch.
Verne [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-20-2015, 07:31 PM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
don't assume a drain plug confirms it's an M22, i've added drain plugs to a few M20-21s i had apart. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
