Old 05-20-2015, 02:51 PM
old5.0 old5.0 is offline
Default Re: New super car warranty
Regarding Hennessy, that article doesn't even scratch the surface. Beyond the legion of customers he screwed, he's also, to put it bluntly, an *******. He left a swath of destruction a mile wide in his wake and while some claim that he's turned over a new leaf, I wouldn't risk my money to find out.
Old 05-20-2015, 03:13 PM
427TJ's Avatar
427TJ 427TJ is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: black69</div><div class="ubbcode-body"> Charlie, referring to something 13 yrs back does not seem fair. I just checked, and maybe they are not as bad as you infer, as Jay Leno bought a 2011 Camaro from them. I think being able to convince Jay Leno is not an easy accomplishment. </div></div>
We must assume that Leno was put at the front of the line and that Hennessy made sure his car was perfect, or close to it, before they delivered it to Leno. Upset customers are one thing, an upset Jay Leno is another.
Old 05-20-2015, 03:35 PM
427freak 427freak is offline
<span style="font-style: italic">&quot;After 2-3 yrs you would be on your own, and some of these cars wont go in to emissions testing until after the warranty expires. Here in the state of Illinois, I believe its 5 yrs from new, and then every 2 yrs.&quot;</span>
In California first smog is 4 years now, just changed from 5. Every 2 years after that. Just had one smogged, no more sniffer on cars with OBDII. Just did visual, checked for evap leaks and plugged into OBD port to look for codes. If what you do to the engine is Calif legal (per the visual, CARB stickers) and it does not trip the check engine light it is good.
Dana
MBTMF
Old 05-20-2015, 06:16 PM
Stefano Stefano is offline
We at NicKey do offer a limited warranty on our packages and stand behind the workmanship on anything we build.
Warranties are subject to many variables and range from no warranty up to three years.
As an example we offer a two year or 24,000 mile, which ever comes first on our most popular option the ZL1-Stage II 850hp package. Not many shops are backing up that much HP.
The most important aspect of any warranty is how it is handled in application. If you have to fight for a valid claim, it may not be worth the paper its written on and just about any attorney can make a cause for it being the owners fault and not the builder.
It is also important know exactly what is and what isn't covered, parts, labor, towing, shipping etc.....
It would be difficult if not almost impossible for any Performance shop to match an OEM warranty.
In practical application we at NicKey have built more than 100 serialized cars in the past decade with many, many more shop cars. I am not aware of one single warranty issue which was not resolved with 100% customer satisfaction.
Next, I would like to clarify some of the miss-information posted regarding our builds. There is just about nothing we haven't done to an LS engine. To insinuate that we just bolt parts on for our builds is false. There is no magic wand to performance, many of the top performance shops even use many of the same Key parts and components and have similar performance results. Our builds/packages are very safe and sound, none are pushing any performance envelope.
Regarding the emissions issue. We build cars with 50 state complaint emission and CARB certifications and we build cars which are for off road use competition purposes only. Passing an emissions test and being emissions legal are not necessarily the same thing. It is also not accurate and false that another shops car will pass emissions while ours will not, under the same circumstances.
I would also like to point out that Ken / Kristen Lingenfelter are a class act and own a top notch Performance operation. If someone chose them to build their car, I cannot see how they could go wrong. We built a NicKey Camaro as a joint venture a while back, and it turned out fantastic.
Click to visit the Nickey Performance Facebook--&gt;
Old 05-20-2015, 07:57 PM
black69 black69 is offline
Thanks for responding Stephano. I focused on the term used in the description of your 700HP package, i.e. <span style="font-style: italic">It transforms your ZL-1 to true Super Car status and performance without opening up the engine.</span> I thought I made it clear in my post, I only referred to Nickey as not touching the heads or block. If that insinuates only a bolt on mentality, those are your words, not mine. I don't know what else to say there.
So to Charlie's point, I should have asked you how you get the 700HP without touching the heads and block? I cant put the tooth paste back in the tube at this point, so I am asking now. Is there a basic answer? I see same parts (like pulley ratio), and polishing of similar components, etc, the other guys still do. I can understand there could be some secrets involved here also, that maybe cant be disclosed. Is possible the heads on the stock ZL-1 are good enough to not really need modification to net any real meaningful HP gains compared to other modifications?
Old 05-20-2015, 09:36 PM
There are times we need to get into the engine and times when its not necessary. With this particular Option: ZL1 Stage I, 700 fwhp / 600 rwhp there is no need to get into the engine. There really aren't too many trade secrets as the LSA engine has been out for quite some time and literally, hundreds of shop have been working on them.
We got one of the First ZL1s and tested our components/pkg on it. It made the power we needed and we have been improving and revising the option since then.
All of the info on the Webs sites is not 100% accurate.
Here are the parts necessary to Achieve the power levels. (There are other ways to get there, but this is the most cost effective. IMO)
ATI Damper
Lower Pulley
Idler relocation bracket
Belt
Injectors
Cold Air Box
Headers
Off road connection pipes
NicKey Super tune
93 Octane Premium Gas
Old 05-20-2015, 09:55 PM
Thanks Stephano, that helps a lot. I just read about the one car you did with the Lingenfelter engine that was at Indy in 2012. Very nice. I would not mind driving that around.
https://www.mecum.com/lot-detail/SC0...Coupe/6-Speed/
I also read the warranty that was refered to earlier in the thread for Magnuson super chargers. I can see all the subtle differences one could get into, on a warranty claim. For example, they go as far as requiring no more than 91 octane (last page), if you sign up for their warranty. Looks like they can protect themselves, if they wanted to.
Old 05-20-2015, 10:13 PM
NicKey Stage I ZL1.
This is the most recent Stage I we just finished up.
Old 05-20-2015, 11:02 PM
That looks like a nice flat torque plot!. I went and looked at the Lingenfelter plot (although dated), and it did not look as flat. I would judge yours as better.
Old 05-20-2015, 11:21 PM
kwhizz kwhizz is offline
As far as Stefano tuning these engines and getting power without getting inside the engine........Nickey tuned my Chevelle without doing anything mechanical to the engine........Headers, a smaller transmission (4L70E) and Stefano's tune gave my &quot;Stock&quot; LSA 570 rwhp..........and it idles like a 283......LOL......
Ken
